April 12, 201214 yr You need more picsmore pics of what lol ?Just random shit, he don't give a fuck. Take a close-up of every capacitor on that amp. LMAO!Gett'r done!
April 12, 201214 yr Author nice updates mangoThanks More equipment, same progress... Lol shut up, least I got all my equipment
April 12, 201214 yr Well, it looks like you've run out of excuses. Lol. You're on your way to quite a build, I'm looking forward to some more progress.
April 28, 201214 yr Author spent around 350 bucks today didnt get to much done today as it took awhile to get all the wood and stuff... got a lot of the plan worked out as to what its gonna look like... working on it again tomorrow so ill have more updated then
April 28, 201214 yr Author I only see one car of spray foam. I'm a little disappointingLol I plan to use wood to block off the gaps not foam
April 29, 201214 yr Author Just more buying random shit, no building, same ole song... mehbuying random shit... wow loland no building huh ...2x4s to make the floor level:floor done...Well the front floor is done... its gonna go over the hump and back to the trunk a lil bit after said and done1 layer of the front sides mocked up (im doing double layer everything lol) the front baffle will be 4 layers thick though my cutting station lol:thats all i got done today before i had to go to work.... the saw blade dulled out so i have to go get another one tomorrow...plus it started raining lol Edited April 29, 201214 yr by 16K
May 1, 201213 yr Author got all the sides and the back done today...didnt get to take pics cause it got dark before i was done... starting to look like a wall thoughtomorrow ill work on the port and the front baffle... wait til you see the port just need to figure out the cubic feet now and how long the port needs to be.
May 2, 201213 yr Author Thanks guys !! Heres more pics heres where the front baffle will connect:the top: as you can see im doing a grooves so it seals perfect... i did grooves EVERYWHERE lolshowing more grooves:got the sides screwed in:got the back part of the box done as well:test fitting 1 layer on the roof:got the roof done... not mounted yet.. right now its just sitting on top:random pics lol:gonna brace all the corners with these:didnt have the jig today so ill be working on the front baffle tomorrow... i already have the back piece done... just not gonna screw it in yet til i get the subs mounted. Edited May 2, 201213 yr by 16K
May 3, 201213 yr Author nice!!!She's coming right along, keep it up. thanks guys didnt get much done today was pretty busy... but got the port figured out..heres some pics with the back on... not mounted until i get the subs in.... also those aluminum pieces arent stuck on yet... just showing where their gonna behopefully get port and front baffle done tomorrow... might work on battery box as well... Edited May 3, 201213 yr by 16K
May 3, 201213 yr Author uh oh, its got wood hehe wall is 13 cubic feet.... port is 202 in^2 tuned to either 36hz or 38hz... havent decided yet.
May 3, 201213 yr Author 37 lollol i wanted to tune for 35hz... but my port would have to be too long and i dont have enough space for it... 36 would barely fit so i might go with 37
May 4, 201213 yr Author Nice job, your definitely gonna feel that bass!thanks man cant wait to hear it got the port done.got one layer cut for the front baffle... no holes yet... that will be tomorrow...wood cut for the battery boxheres the top on... still need to put the front and back sides on ... this was just a test fit to make sure the hatch would close... and it did dont know if ill do much tomorrow as i have to work early... but im off saturday so ill be workin on it all day Edited May 4, 201213 yr by 16K
