Well i got the holes all done in the baffle i guess tomorrow ill get it glue and screwed on. Bit for the router should be here to do the port opening as well.
  • Replies 167
  • Views 19k
  • ncacoates
    ncacoates
    Has absolutely nothing to do with performance but i saw it and had to have it lol. Makes it look so much better to me at least.
  • Here you go guys bracing done and mostly carpeted. Had to throw the 4 sa-12s in just to see what it looked like lol.
  • Built a little amp rack to hold the amps on the box tonight. Box should be going in the car tomorrow just gotta paint the port and seal all the joints inside the box.
Very nice sir :popcorn: I had an Escape and know how little room is available in those trucks.
Got the router bit in to cut the port opening and bought a new sander to clean everything up today. Still gotta glue and screw down the baffle and finish bracing tomorrow. Hopefully my order comes soon with the carpet and and other odds and ends so i can finish that up.
damn thats sexy... shit is gonna BANG
so far so good box looks solid
Finally got the top on and most of the bracing done. Once all the bracing is done im gonna get the carpet on it tomorrow. Yes i know i over brace but that's just how i roll.
Box looks perfect. Rounded over edges, braced for hell and back. :D
+1
braces look perfect :drink40:
Thanks guys I can't wait to get it done. I'm looking forward to the hair tricks and flex.
box looks beautiful!!!
The hell did you use for bracing BTW??? Looks like it could hold more than 2 fat versions of me... lol :peepwall:
Box is looking good. No bracing for the mounting baffle?
Mounting baffle shouldnt need a brace if built right, side wall baffles will suffice.
Where can I find the data that supports your answer?
There are 8 12" subwoofers with over 6kw mounted on the same baffle. It looks to me like the spacing between subwoofers is 3-4". The integrity of the mounting baffle has been compromised. I would think bracing the mounting baffle is a logical choice to make.
I asked because I ask always learning from others :)
Edited by edouble101
Multiple build logs using similar equipment if not more power, if thats not enough data then i guess none of us no what where doing. Boxes tend to flex when underbuilt or poorly built, plain and simple. Double baffling and multiple side wall threads are usually adequate for bracing.
No worries guys there are 4 more braces going to the baffle lol. Thanks for the compliments guys and expect plenty more to come later on today.
Definitely think that is a good idea, if not a necessity on panels that large.
I am really anxious to see your carpeting skills! Mine suck lol.
shyt that is nice!@! :fing34:
Looks to be a Beast of an enclosure!!! Nice Work!!
I wish I had your carpeting skills
