February 14, 201213 yr Author Well i got the holes all done in the baffle i guess tomorrow ill get it glue and screwed on. Bit for the router should be here to do the port opening as well.
February 14, 201213 yr Very nice sir I had an Escape and know how little room is available in those trucks.
February 15, 201213 yr Author Got the router bit in to cut the port opening and bought a new sander to clean everything up today. Still gotta glue and screw down the baffle and finish bracing tomorrow. Hopefully my order comes soon with the carpet and and other odds and ends so i can finish that up.
February 16, 201213 yr Author Finally got the top on and most of the bracing done. Once all the bracing is done im gonna get the carpet on it tomorrow. Yes i know i over brace but that's just how i roll.
February 16, 201213 yr Box looks perfect. Rounded over edges, braced for hell and back. +1braces look perfect
February 16, 201213 yr Author Thanks guys I can't wait to get it done. I'm looking forward to the hair tricks and flex.
February 16, 201213 yr Finally got the top on and most of the bracing done. Once all the bracing is done im gonna get the carpet on it tomorrow. Yes i know i over brace but that's just how i roll.The hell did you use for bracing BTW??? Looks like it could hold more than 2 fat versions of me... lol
February 16, 201213 yr Box is looking good. No bracing for the mounting baffle?Mounting baffle shouldnt need a brace if built right, side wall baffles will suffice.
February 16, 201213 yr Box is looking good. No bracing for the mounting baffle?Mounting baffle shouldnt need a brace if built right, side wall baffles will suffice.Where can I find the data that supports your answer?There are 8 12" subwoofers with over 6kw mounted on the same baffle. It looks to me like the spacing between subwoofers is 3-4". The integrity of the mounting baffle has been compromised. I would think bracing the mounting baffle is a logical choice to make.I asked because I ask always learning from others Edited February 16, 201213 yr by edouble101
February 16, 201213 yr Multiple build logs using similar equipment if not more power, if thats not enough data then i guess none of us no what where doing. Boxes tend to flex when underbuilt or poorly built, plain and simple. Double baffling and multiple side wall threads are usually adequate for bracing.
February 16, 201213 yr Author No worries guys there are 4 more braces going to the baffle lol. Thanks for the compliments guys and expect plenty more to come later on today.
February 16, 201213 yr No worries guys there are 4 more braces going to the baffle lol. Thanks for the compliments guys and expect plenty more to come later on today.Definitely think that is a good idea, if not a necessity on panels that large. I am really anxious to see your carpeting skills! Mine suck lol.
February 17, 201213 yr Author Here you go guys bracing done and mostly carpeted. Had to throw the 4 sa-12s in just to see what it looked like lol.
