January 11, 201214 yr I'm loving the finish on the box, If I kept the jeep, I definitely would have done that.
January 11, 201214 yr Author Here's a couple more pics, how about some amps this time? First up is the IA 6.4, only powering a pair of 8" Powerbass 4xl pa mids in the doors atm.And here's the SAZ-3500D.
January 12, 201214 yr Author I need to add these and another fuse holder tomorrow so I can optimize fusing for MECA.Seat down view for judges. When I add the duals, I'll clean it up a bit here.Seat up view for me.Quick shot from the back.
January 12, 201214 yr Author That Line-X enclosure looks Awesome !!!Nice enslosure and headunit bro, now hurry up and finish I'm loving the finish on the box, If I kept the jeep, I definitely would have done that.Nice box bro. Im diggin it.Gonna be a buckin bronco very soon.Thanks guys, the box does look good but the tuning is off and I want to try to get a bit more volume so it won't be permanent. The Rhino Liner is nice but it's hard on the carpet so I will probably do something different on the next one.
January 12, 201214 yr The enclosure came out sweet looking. To bad its not what you wanted. My big question is did you fit the 8"s in the front doors?
January 12, 201214 yr Author Thanks, fitting the 8" speakers in the door was a piece of cake, I have plenty of room. I have 8" pa mids in the doors right now. I'm going to swap them out with the Soundstream coax soon. They will be temporary as well, when I decide to start glassing, they will be replaced.
February 5, 201213 yr Author MORE PICS!!!Anything in particular you would like to see?nice build ohjayThank you sir, it's a work in progress. There will be updates pretty soon.
February 11, 201213 yr Just cause its a bronco, Any thing works for me till my parts show up... (no homo)
February 12, 201213 yr Author It is certainly rough on the carpet. It's easy to clean though, wash it with soap and water.
February 17, 201213 yr Did you spray the bed liner on the box or roll it? What brand did you use?Came out great. Nice setup man.
February 20, 201213 yr Author Lets get that video walk around I need 1 good day of nice weather first. I've never done one before either, I guess I should check a few out to get some ideas so it doesn't suck (probably inevitable with my cheap digicam). Any suggestions on what I maybe should include or stay away from? What do you want to see? A link to a good example or two for reference might help.nice build manThank you sir, it's been fun but I think there will be some rebuilding soon, some of the equipment will stay while some will have to goooo.Did you spray the bed liner on the box or roll it? What brand did you use?Came out great. Nice setup man.Thanks for the kind words, I've enjoyed this setup a bit more than I had anticipated before starting (it was almost completely experimental). The box was sprayed at a shop with genuine Rhino Liner.Lets get that video walk around +1See reply above. Is there anything in particular you would like to see since we share the same generation Bronco?
