May 2, 201313 yr Author I recorded two new videos this morning. I'm pretty much done with the system for the year. On my to buy list, is a new desktop, a new camera, and SDS. This system where it's at is very good. And I enjoy the way it is right now.
May 2, 201313 yr nice man! .... I wish I was closer to some of ya'll.... I also wish I had never been unemployed... my car needs alot of love and I don't want to get rid of it anytime soon... Want to do so much to it..... Especially with the audio I recorded two new videos this morning. I'm pretty much done with the system for the year. On my to buy list, is a new desktop, a new camera, and SDS. This system where it's at is very good. And I enjoy the way it is right now.
May 4, 201313 yr Author Took some more pictures! First two was me at my Roommate's military base, then the rest of the first phase of lighting upgrade.
May 5, 201313 yr Author Ok, so as I continue this light project, I have a few updates. Starting next with the grille, one light per section wasn't bright enough(top/bottom). So I will use two per. This will involve extended the cables per tube. For this, instead of using the speaker wire, which was previously done, works fine, but I will take a bit neater approach by utilizing Cat5E cable. For the interior, I will probably just purchase their interior kit. With the two remaining tubes, I may place them inside the enclosure(not sure). What the top will look like, with both tubes being used. I will be extended them about 15ft per cable Silly Bassink Hopefully this goes well Benefits of working in a data center
May 5, 201313 yr Hey I don't work at a data center so I can't get nice wire like you lol that's all I had and it worked haha
May 5, 201313 yr Author Holy hell did that take forever!!! For me to install the four 15" tubes in my grille took about 6-7 hours.. yeah. One tube gave me the most trouble, as I had to keep rewiring it because a wire seemed to always touch eacth other where I was extending it. But whatevs, I'm very happy with the outcome. Check out these pics. And here you can hear the birds chirping lol. Shitty video, looks much brighter in person.
May 6, 201313 yr Author Alright, so last update for the light project. I spent a few hours today cleaning up everything. I ended up extended the port hub for the six small tubes to reach the rear, I installed the main brain and the 4 outer tube switch under neath the dash. I mounted the last two tubes under the rear seats. Not the best locations, but it will do. Overall, I'm veriy happy with this project. All is up and functional. If anything, I would like to find a way to keep lights on but only whenever I start the car. Currently, I have to power on/off with remote. And that's all I have
May 6, 201313 yr Author Nice approach Thanks chop grille lights looks great! Thanks Kyle! looking good Sen! Thank you Shogen Hey I don't work at a data center so I can't get nice wire like you lol that's all I had and it worked haha haha just teasing you. Looks good, but you are missing the knight rider red light in the grill! I can change it RED!
May 30, 201312 yr For those wondering, here is the setting of my amp.I heard if you want the dB's you must turn up the bass boost.
May 30, 201312 yr For those wondering, here is the setting of my amp.why is gain all the way to six volts?
May 30, 201312 yr For those wondering, here is the setting of my amp.why is gain all the way to six volts?. Bc it's turned all the way down. Or I guess it could be 2/3? I'm gonna bet all the way down.
May 30, 201312 yr For those wondering, here is the setting of my amp.why is gain all the way to six volts?A better question is: how do you know it's set to 6v?
