  • Replies 1.1k
  • Views 93.8k
  • Updates will come slowly. New SSA amps going in and the sundowns are coming out. I am also adding and xstatic batcap 400 along with the battery already there. Little progress today. As you can se
  • I recently came across a steal of a deal for an SSA ICON 12. So I had some free time today and put some goodies in. I just put this in for now as it will change as I get more time. Here is what my cur
  • I suck at pictures when I get busy.
This is where I stopped for the day. I finally got a table saw and cutting wood is so nice now.
Looking good!
Thanks Senchez.
I am going a bit smaller all the way around. Don't need that much bass anymore, but rather a more refined bass. I hope on both anyway.
looks good!
Edited by lithium
Nice enclosure so far :fing34:, specs on old box vs new box.
  • Admin
New box specs
35.75" wide
18.75" high + .75" double baffle
21.5" deep
4.51 cubes before displacment
4.15 cubes after displacment (sub & bracing)
Port
3.5"w
 20" h
40.5" l
70sq" of port tuned @ 30 hz with a vent match of .09
I have been kicking around some box designs and I have a certain foot print I want to keep.
This is where I currently stand.
Evil 15 D2
Box will be 40"x21.5"x22.5" . Port is going to be 6"x20"x42" at just under 33hz with a total of 120" of port.
Vent match is .034, 37.906ft/sec.
My plan is to take my xcon box and cut it down and go from there.
More to come....
Old box
Side by side shot. The only difference I can tell at this point is I lost a little out put, but it seems to hit harder.
Hope to start the amps racks next week.
Looks good!
  • Admin
  • 2 months later...
At some point this build will get finished but till then she just reach a milestone.
:woot:
  • 8 months later...
So I decided the old girl needed a little lift. So I put Toyota FJ coils in the rear and raised the Bilstein's up one notch. She looks pretty freshened up and is more responsive, so that is a good thing because that means there is no more coil sag.
FJ springs
New side window swag.
As she sat before the fun and M5 sent me thin snow, but that was not going to stop me.
Front before
Rear Before
After and yes I did this in the snow because it was only to be a dusting not 5 inchs!
Rear
Front
All around I should have gained an inch in height and with stiffer springs in the rear you can not tell it is full of audio equipment and batteries.
Next up when it get nicer, summer tires and rims!
Once it gets nice out I will measure to see how much height I gained.
