January 31, 201313 yr yeah it is. it pooped out on me.,first the pico then one channel had horrible static and one stopped working. Same here lol. I like the sound of the Kenwood better honestly. If it had the crossovers I would definitely like it more than the Pioneer decks.
January 31, 201313 yr that's crazy bright. How do you like those tweets? great for vids :-) honestly I like them. they take a lil bit of tuning to make them sound good but when you get it right its nice. they sounded a whole lot Better when I had my 880prs.but.they still sound good on the kenwood I'll keep that in mind. Thanks
February 7, 201313 yr Author got a bit of work done today!FIshing the bolts through.Tyler unbolting the muffler.What I'm doing.ANd what it's all for.. A trailer basket will hold up to 150 Lbs in extra stuff while traveling The final result.. should be great for going places.. Has a 46x28.I received my 16ft of "cool white" LED stropsThe two strips for the portTinning the wiresAll soldered up and heatshrinkedboth doneAll lit up and pretty, I need to repaint the port to make it look pretty again.
February 7, 201313 yr Author It was a good 2db loss lol, so probs never. I'm going to trim it out later but its a lot of work
February 10, 201312 yr Author The "Gramma Trailer" as Senchez calls it was a Success! Made traveling 100x easier and more comfortable.
February 12, 201312 yr The "Gramma Trailer" as Senchez calls it was a Success! Made traveling 100x easier and more comfortable.Hahahaha! It has its uses!!
February 12, 201312 yr Good thing you have 300hp to pull all that weight.Too bad its a v6 though If it's the 3.7, it should do fine imo. Looks good Jules
February 14, 201312 yr Author Little update! What I'm working with 3/8" x 1 1/2" Aluminum bar.Ensuring that all the holes line up properlyOne down.. Many to goMore done..The final product.. I know they're not perfectly centered.. But I like my overall job with the tapping. There are a total of 15 tapped holes on each side for my M8 X 1.25 bolts.Close up..Starting to get them in..All the 1/0 connected and bolted downAll neat and clean!
February 14, 201312 yr Author Oh, and why the fuck are Metric bolts so expensive? I spent more on the bolts than I did the Aluminum.
February 14, 201312 yr Oh, and why the fuck are Metric bolts so expensive? I spent more on the bolts than I did the Aluminum.Don t use metric.. I used 38-24 on all my custom blocks.
February 14, 201312 yr I started to make bars for my die hards and said fuck it, and ran jumpers. I have 2 aluminum bars siting in garage. I bought 1/2 in bars and couldn't get threads to catch, oh well. Looks good
February 14, 201312 yr Good thing you have 300hp to pull all that weight.I have ~1300lbs extra in the vehicle on just 161hp stock. No, tranny issues whatsoever. All i need is new brakes at this point and it's fine. The added weight requires a different approach on taking off without squealing tires but i'm used to it now.
February 14, 201312 yr Author I started to make bars for my die hards and said fuck it, and ran jumpers. I have 2 aluminum bars siting in garage. I bought 1/2 in bars and couldn't get threads to catch, oh well. Looks goodIt worked out pretty well.. I used the posts to mark where the holes needed to go by tapping with a hammer to make an indentation. Then used the drill press to carefully tap the bar. I'm pretty happy with what came out.The bars make it 500x easier to wire everything up instead of having 3-4 terminals on a single post.
