yeah it is. it pooped out on me.,first the pico then one channel had horrible static and one stopped working.
Same here lol. I like the sound of the Kenwood better honestly. If it had the crossovers I would definitely like it more than the Pioneer decks.
  • Replies 467
  • Views 53k
looking good
that's crazy bright. How do you like those tweets?
great for vids :-) honestly I like them. they take a lil bit of tuning to make them sound good but when you get it right its nice. they sounded a whole lot Better when I had my 880prs.but.they still sound good on the kenwood
I'll keep that in mind. Thanks
got a bit of work done today!
FIshing the bolts through.
Tyler unbolting the muffler.
What I'm doing.
ANd what it's all for.. A trailer basket will hold up to 150 Lbs in extra stuff while traveling
The final result.. should be great for going places.. Has a 46x28.
I received my 16ft of "cool white" LED strops
The two strips for the port
Tinning the wires
All soldered up and heatshrinked
both done
All lit up and pretty, I need to repaint the port to make it look pretty again.
Looking good. When are you going to seal it off?
  • Admin
Good thing you have 300hp to pull all that weight.
Too bad its a v6 though :(
The "Gramma Trailer" as Senchez calls it was a Success! Made traveling 100x easier and more comfortable.
Hahahaha! It has its uses!!
If it's the 3.7, it should do fine imo.
Looks good Jules
Considering a Change in the Mustang..
I'm here for you buddy...
  • Admin
Keep us updated. :)
Little update!
What I'm working with 3/8" x 1 1/2" Aluminum bar.
Ensuring that all the holes line up properly
One down.. Many to go
More done..
The final product.. I know they're not perfectly  centered.. But I like my overall job with the tapping. There are a total of 15 tapped holes on each side for my M8 X 1.25 bolts.
Close up..
Starting to get them in..
All the 1/0 connected and bolted down
All neat and clean!
Very nice sir
Oh, and why the fuck are Metric bolts so expensive? I spent more on the bolts than I did the Aluminum.
Don t use metric..  I used 38-24 on all my custom blocks.
I started to make bars for my die hards and said fuck it, and ran jumpers. I have 2 aluminum bars siting in garage. I bought 1/2 in bars and couldn't get threads to catch, oh well. Looks good
I have ~1300lbs extra in the vehicle on just 161hp stock.
No, tranny issues whatsoever.
All i need is new brakes at this point and it's fine.
The added weight requires a different approach on taking off without squealing tires but i'm used to it now.
It worked out pretty well.. I used the posts to mark where the holes needed to go by tapping with a hammer to make an indentation. Then used the drill press to carefully tap the bar.
I'm pretty happy with what came out.
The bars make it 500x easier to wire everything up instead of having 3-4 terminals on a single post.
