got a 15" BL and i bought a cadence amp kit and it came with 12 gauge speaker wire was wondering if that size would be okay or should i got alil bigger?
it really depends on how many watts your running... i know when i was running 2k to each of my btls i used 8 gauges for speaker wire.
not really, some people need to compensate for something.
It all depends on how much power you are running.
is there like a chart or maybe a rule of thumb for power vs wire size ratings?
Power Wire:
10 gauge: ~35 amperes
Class D (~70% efficiency) - <350 watts
Class A/B (~50% efficiency) - <250 watts
8 gauge: ~55 amperes
Class D (~70% efficiency) - <550 watts
Class A/B (~50% efficiency) - <400 watts
6 gauge: ~87 amperes
Class D (~70% efficiency) - <875 watts
Class A/B (~50% efficiency) - <625 watts
4 gauge: ~140 amperes
Class D (~70% efficiency) - <1400 watts
Class A/B (~50% efficiency) - <1000 watts
2 gauge: ~220 amperes
Class D (~70% efficiency) - <2200 watts
Class A/B (~50% efficiency) - <1500 watts
1/0 gauge: ~350 amperes
Class D (~70% efficiency) - <3500 watts
Class A/B (~50% efficiency) - <2500 watts
2/0 gauge: ~440 amperes
Class D (~70% efficiency) - <4400 watts
Class A/B (~50% efficiency) - <3000 watts
4/0 gauge: ~700 amperes
Class D (~70% efficiency) - <7000 watts
Class A/B (~50% efficiency) - <5000 watts
Speaker wire:
22 gauge: ~2.2 amperes
8 ohms - <36 watts
6 ohms - <27 watts
4 ohms - <18 watts
3 ohms - <13.5 watts
2 ohms - <9 watts
1 ohm - <4.5 watts
20 gauge: ~3.4 amperes
8 ohms - <96 watts
6 ohms - <72 watts
4 ohms - <48 watts
3 ohms - <36 watts
2 ohms - <24 watts
1 ohm - <12 watts
18 gauge: ~5.5 amperes
8 ohms - <240 watts
6 ohms - <180 watts
4 ohms - <120 watts
3 ohms - <90 watts
2 ohms - <60 watts
1 ohm - <30 watts
16 gauge: ~8.7 amperes
8 ohms - <600 watts
6 ohms - <450 watts
4 ohms - <300 watts
3 ohms - <225 watts
2 ohms - <150 watts
1 ohm - <75 watts
14 gauge: ~13.7 amperes
8 ohms - <1500 watts
6 ohms - <1125 watts
4 ohms - <750 watts
3 ohms - <563 watts
2 ohms - <375 watts
1 ohm - <188 watts
12 gauge: ~21.8 amperes
8 ohms - <3800 watts
6 ohms - <2850 watts
4 ohms - <1900 watts
3 ohms - <1425 watts
2 ohms - <950 watts
1 ohm - <475 watts
10 gauge: ~34.6 amperes
8 ohms - <9600 watts
6 ohms - <7200 watts
4 ohms - <4800 watts
3 ohms - <3600 watts
2 ohms - <2400 watts
1 ohm - <1200 watts
8 ohms - <24000 watts
6 ohms - <18000 watts
4 ohms - <12000 watts
3 ohms - <9000 watts
2 ohms - <6000 watts
1 ohm - <3000 watts
Power Wire:
Speaker wire:
8 ohms - <36 watts
6 ohms - <27 watts
4 ohms - <18 watts
2 ohms - <9 watts
1 ohm - <4.5 watts
8 ohms - <96 watts
6 ohms - <72 watts
4 ohms - <48 watts
3 ohms - <36 watts
2 ohms - <24 watts
1 ohm - <12 watts
8 ohms - <240 watts
6 ohms - <180 watts
4 ohms - <120 watts
3 ohms - <90 watts
2 ohms - <60 watts
1 ohm - <30 watts
8 ohms - <600 watts
6 ohms - <450 watts
4 ohms - <300 watts
3 ohms - <225 watts
2 ohms - <150 watts
1 ohm - <75 watts
4 ohms - <750 watts
3 ohms - <563 watts
2 ohms - <375 watts
1 ohm - <188 watts
2 ohms - <950 watts
1 ohm - <475 watts
1 ohm - <1200 watts
1 ohm - <3000 watts
PERFECT
Edited by ShawnFleming
i used 8 gauge for my 2 BL 12's. works fine. tight but works well
