Posted June 9, 201214 yr would i be wasting my money on this item ? the desperation says it only handles200 amps my amp is clocking about 450amps so would it stop at 200amps or would it read higher under power? http://www.ebay.com/itm/350566662011?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
June 9, 201214 yr if it can only handle 200 amps, then i dont see it reading much more than that, hence, useless, unless otherwise.
June 11, 201214 yr so to measure current in DC it has to be wired in series. So if you exceed 200amps then kill you fuse holder and render it useless. Unless it has a fail safe in placeunless it works via shunt200amps at 12vdc = 2400wattsor on 14vdc= 2800wattsso you decide! Edited June 11, 201214 yr by CrazyKenKid
June 11, 201214 yr You gotta ask why you even need this? It looks like it would be mounted back by your amp. So you would hardly see it. Just pick up a cheap voltmeter and run that.
June 12, 201214 yr Cheese is good with crackers, but potato chips dipped in maple syrup and fried in bacon grease will give you the shits for days. I once saw a turtle get in an arm wrestling match with a small mouth bass. Purple is the color most queers associate with gays, while lesbians will still eat meat even on tuna bread with cottage cheese. Asphalt.
June 12, 201214 yr Cheese is good with crackers, but potato chips dipped in maple syrup and fried in bacon grease will give you the shits for days. I once saw a turtle get in an arm wrestling match with a small mouth bass. Purple is the color most queers associate with gays, while lesbians will still eat meat even on tuna bread with cottage cheese. Asphalt.That is badass! If you ever get the chance I suggest you go to a turtle arm wrestling match.
