Posted June 13, 201214 yr I'll soon be picking up a second Skar VVX which leaves me to a new box build (:It'll be going in the rear cargo area of a 99 Jeep Grand CherokeeI'd did it tuned somewhere around 33-34Hz and about 5 cubes after displacementSubs up and port backWill be using 3/4 mdf and the top will be a double baffle (2 3/4 pieces) and the subs will be countersunkwill be building an amp rack off the back (so facing the front of the car) but that really isnt part of the box designMax dim are 40 wide 25 deep and 20 tall, (pref 15 tall though)Everything I will be running is2 Skar VVX 15's D4 wired to 1 ohmConcept HPN-1500 (clamped clean at 1100)Big 3 upgrade (to be done when i build the new box)I do have a volt meter to check up on thingsas said earlier, will be in a 99 Jeep Grand Cherokeeany help would be very much appreciated or suggestions on different specs (volume, tuning and such)also would like some ideas on terminals
June 14, 201214 yr Is this for two 15''vvx . try this box 16''tall 40''wide 24''deep with a 5''tall 14''wide 18''deep port that would be like 5.07cf net tuned to like 36hz them skar subs kill the lowlows so you dont need to tune so low with them and thay will still get down. and put some more power on them.....
June 14, 201214 yr Author yes that for to, and do i just put the port on the botton centered? like a box per say? and i knew about the lows but didnt knew i could tune higher and stil get low cuz of it. thanks man! any chance you could through up a pic of the box (: other wise hopefully ill have it started this week
June 14, 201214 yr port on the bottom in the center on the box.......set your ssf on the amp at about 30hz and it will still getdown low
June 14, 201214 yr Is this for two 15''vvx . try this box 16''tall 40''wide 24''deep with a 5''tall 14''wide 18''deep port that would be like 5.07cf net tuned to like 36hz them skar subs kill the lowlows so you dont need to tune so low with them and thay will still get down. and put some more power on them..... Taking the subs combined .34 cubic feet of displacement and the ports 1.069 cubic feet of displacement into consideration, that box would be about 6 net cubic feet. That's also on the small end of port area. I wouldn't put any more power on them because you won't be able to notice the increase in power unless its extremely significant (1,000 watts or so) and also I wouldn't take his opinion on "skar subs kill the lowlows" too much to heart.That being said, I have no idea what your goal is for your box. But I can throw you out one that i would make which fits my goals ( won't necessarily help you but it would sure make me look candid). 19 tall by 40 wide by 24 deep would be external dimensions. I would make a slot port. So it's height would be 16.5 inches and i would make it 6 inches wide for a total of 99 square inches of port area giving you roughly 16 square inches of port area per cubic feet. This L-shaped slot port would be 30 inches in total length and it would maintain it's 6 inch width throughout the L. Net volume = 6.14 feet. Tuning frequency is 33.71hz.It would work for me.
June 14, 201214 yr Author i like both boxes but i want a box down near cubes. my box is three and because of the power its a hair to big, and in the future ill be running more like 2 k to them
June 14, 201214 yr Author id prefer 5 after displacement, that would be awesome, and i guess tuning up to you, but 36ish hz
June 15, 201214 yr Imagine that, Kevin doesn't know and won't respond. What an effin' surprise.Is it possible to sell the one you have and buy two of something else? IMO that'd be the best way to use 5cuft.
June 15, 201214 yr Author Imagine that, Kevin doesn't know and won't respond. What an effin' surprise.Is it possible to sell the one you have and buy two of something else? IMO that'd be the best way to use 5cuft. why sell it and get somethin else?
June 15, 201214 yr Author to owner of most companies isnt respon for making box designs for people. . . and i want it to be 5 cubes, the subs are going to be over powered and each one is reccommend to 3 so 6 is to big. . . i have more than enough space for some like 12 cubes
June 15, 201214 yr to owner of most companies isnt respon for making box designs for people. . . and i want it to be 5 cubes, the subs are going to be over powered and each one is reccommend to 3 so 6 is to big. . . i have more than enough space for some like 12 cubesActually, um, wow, nevermind.
June 15, 201214 yr Author to owner of most companies isnt respon for making box designs for people. . . and i want it to be 5 cubes, the subs are going to be over powered and each one is reccommend to 3 so 6 is to big. . . i have more than enough space for some like 12 cubesActually, um, wow, nevermind. what? go ahead im in nowa defnding anyone lol. idk i figured owneres just dont give input, am i wrong?
June 15, 201214 yr Yes, all owners who have pride in their products and their customer service always help the customer.
June 15, 201214 yr Author Yes, all owners who have pride in their products and their customer service always help the customer. i guess when you put it like that yeah. just most comanies now a days are money money money and because they are so big in businiess you never see them help people, good to know i guess
June 15, 201214 yr Yes, all owners who have pride in their products and their customer service always help the customer. i guess when you put it like that yeah. just most comanies now a days are money money money and because they are so big in businiess you never see them help peopleAnd I try my best not to support companies like that. Just my .02.
