Posted June 14, 201214 yr I sold my Q's to a local guy with a S10 extended cab truck. He wanted to be able to see out of the back window and not wall it. There is very little room to work with but I managed to get 10.8cu after all displacement and bracing etc. Subs forward and port firing up, I have heard this is the way to go in these little S10's so hopefully it is loud and sounds good on music. This guy will be eating the steering wheel but this is what he wants, he is much smaller than me so I guess its not big dealMy new shop tables, huge and I love them.The box is on the small side but hopefully it will be ok. Here is what I have doneHis truck is red so this subtle add of red in the port and in the flush mount trim is a nice touch I thought.I will post pics installed in a day or so if someone wants to see. Edited June 14, 201214 yr by swift
June 14, 201214 yr Good job with the box. I still havent mastered carpeting.Let us know how it sounds.
June 14, 201214 yr Nice Shop, and the box came out great. Still waiting for my Sp4's they should be just about done by now. When Did you order yours?.
June 14, 201214 yr Author Nice Shop, and the box came out great. Still waiting for my Sp4's they should be just about done by now. When Did you order yours?.I think on June 6th.if they get here before July 4th I will be stoked. My truck is normally used for the music in a huge firework show. It's always really cool but may not make it this year
June 14, 201214 yr Nice Shop, and the box came out great. Still waiting for my Sp4's they should be just about done by now. When Did you order yours?.I think on June 6th.if they get here before July 4th I will be stoked. My truck is normally used for the music in a huge firework show. It's always really cool but may not make it this yearI hope they make It there in time for ya, I ordered May 22 so I hope soon, so I can start planning and making progress with my enclosure, I probably won't have It running till mid July.
June 14, 201214 yr Nice enclosure. Try contacting Shawn at Fi if you need to check on the woofers. I know he said there busy right now but I purchased a large order may 10th and are scheduled for delivery tomorrow.
June 14, 201214 yr guy must be a midget....2 15's is pushing it for me in my ext. cabI'd like to see installed pics Edited June 14, 201214 yr by Tim Harmening
June 15, 201214 yr Author Fits like a glove, lolHe is gonna do more, I just build the box. He has all stock electrical now so the gain is way way down on the Crunch amp. But it sounds amazing all sealed up. It is going to be fkn loud as balls when he can go full tilt.
June 15, 201214 yr looks good, but personally with that amount of space I would of chosen or suggested 15's instead. but none the less it looks goodAlso it'd be considered a wall due to it being above the window line.. Are these SSD's or Q's? Edited June 15, 201214 yr by Julian
June 15, 201214 yr looks good, but personally with that amount of space I would of chosen or suggested 15's instead. but none the less it looks goodAlso it'd be considered a wall due to it being above the window line.. Are these SSD's or Q's?I agree with going with fifteens instead. I think that they are q's. Nice looking enclosure by the way.
June 15, 201214 yr Author looks good, but personally with that amount of space I would of chosen or suggested 15's instead. but none the less it looks goodAlso it'd be considered a wall due to it being above the window line.. Are these SSD's or Q's?The first sentence says Q's, lol. Also there was nothing to suggest or not suggest really, he bought my subs and said "can you build a box for this" Window line only means anything to people that compete, You can perfectly see out the rear view mirror which is what he wanted.But yes, if it was me personally I would have probably only 2 12's. Those trucks are tiny.
June 15, 201214 yr No way 18's might be a tight fit, the work is worth it IMO.Nice work and it should be killer in there.
June 15, 201214 yr looks good, but personally with that amount of space I would of chosen or suggested 15's instead. but none the less it looks goodAlso it'd be considered a wall due to it being above the window line.. Are these SSD's or Q's?The first sentence says Q's, lol. Also there was nothing to suggest or not suggest really, he bought my subs and said "can you build a box for this" Window line only means anything to people that compete, You can perfectly see out the rear view mirror which is what he wanted.But yes, if it was me personally I would have probably only 2 12's. Those trucks are tiny.Yep, I've seen that happen too many times before.Sorry I have the competitor mindset I think two 15's would of just met at or a little above the window line.Maybe if/when he blows them I would suggest (tell) him to go to 15's in a more efficient box.
June 15, 201214 yr Author I think two 15's would of just met at or a little above the window line.Maybe if/when he blows them I would suggest (tell) him to go to 15's in a more efficient box.lol, why would he blow them? Just curious what your assumption is based on. The box is alittle small but perfectly fine. Its barely under 11cubes and has over 13in of port per cube. Once again, I'm sure if he cared about window line he wouldnt have wanted to buy 18's? Since I do not even know the guy we can all assume that. Its not my place to (tell) him to do anything. If he asks I will give my advice, but like I said earlier. I would have went with two 12's if that was my truck.
