August 6, 201214 yr Author The back is 2.25" thick, so the amps can be mounted. The Stetsom has rubber mounts built into the mounting locations. I used some washers to keep the amplifier slightly raised off the carpet since it has a fan.
August 15, 201213 yr Baffle on. Next, port will be rounded and the box will be carpeted. A dcon sounds good in this box.
August 17, 201213 yr Baffle on. Next, port will be rounded and the box will be carpeted. A dcon sounds good in this box.
