i hope so or im just ust putting my treo in and going to be really sad... sad.png
The XCON is a great sub, I'm sure if you get a ported box within recommended specs you will be happy.
  • Replies 105
  • Views 10.6k
  • Aaron Clinton
    Aaron Clinton
    Loud is relative to the person and the install. There are a number of factors at play here that effect the output. How much sound is allowed to pass through from the rear into the cabin, what kind o
  • Notorious97200
    Notorious97200
    Maybe you expect too much out of a single sealed 12" ? Some ideas ; Try a ported box. Use aeroports too save space if the trunk is small. Change box position : fire the sub through the rear. more p
  • 1w
Something is wrong :(
My icon was silly loud
Agreed, I'm assuming it is the enclosure.
Its gotta be that enclosure, either just wrong airspace or leaking air like crazy, that sub should be getting down even on the 600 Watts, and be flexin your ride pretty good even sealed especially with 1500rms.
Edited by Optimus_Prime
I hope that you get it figured out, you have an awesome sub!
The inside deminsions of the enclousre are 24x8x15.5. And has some. Bracing
  • Admin
if that xcon isnt loud, you are doing something wrong, even only on 600 rms.
That is what I am guessing, as loud is relative to the install and person, I was still able to render mirrors useless off 240 watts, sealed.
  • Admin
What would cause that clacking noise it sounds like metal hitting glass
98% of the time, that is an air leak.
I just don't understand whats wrong cause I made Tge boxes to all my subs and that trek would murder what I'm getting now and it had less power. And the visonik was keeping up with this. Idk and don't understand I will reseal the box today but ya
Could you post some pictures of how your sub is wired. Curious to see.
Ya later I will it's in parrel positive of one coil to the amp then the negative of Tge other coil to the amp Tge jump the positives together And te negatives together
When you look at the terminals is the red always on the same side of you?
I'm not understanding the question. The coils are on opposite sides and positive and negative are next to each other
Your pictures will show me what I am looking for.
When you look at one set the red will be lets say on the right for example and when you spin the sub to the second set the red should be on the same side of you.
Okay something wierd is happening it looks like something is hit the sub from the inside when it makes that noise I dents right above the word Xcon. But nothing is there. And here are the pics
anyone got anything on this noise and that its coming from the sub. and it looks like something hits it on the inside of the box. the sound it like if u let the dustcap hit your finger nail.
