Posted September 3, 201213 yr Hey everyone. What do you think would be the best for music and spl box size for a 15" Zcon. Been looking but can't find the suggested box sizes on here. Thanks guys.
September 3, 201213 yr http://www.soundsolutionsaudio.com/index.php/product-information/zcon.htmlScroll down and click on the "Enclosure Recommendations" tab.How much power are you running?
September 4, 201213 yr Author Plan on getting this amp Crescendo Audio BC2000D at 1 ohm. Unless you think there is a better choice in amps?
September 4, 201213 yr I would follow the specs suggested by ssa.This. Somewhere around 7 cubes would work well, you could even go a bit larger.
September 4, 201213 yr for 1-2225w I would suggest 6-7 cubes, for more than RMS I would suggest 5-6 cubes before displacement. Make sure you set your SSF appropriately, if not it will lead to softpart suicide.
September 4, 201213 yr dont they recomend between 4-5?, mine is built to 4.5 and have 3000 rms and it sounds really good
September 4, 201213 yr Why in the world would you put one 15 in 7cu box? I would do between 3.75 - 5 cubes
September 4, 201213 yr Why in the world would you put one 15 in 7cu box? I would do between 3.75 - 5 cubesLMFAO I went back and reread to see if he had 2 15's because of the sizes they were suggesting
September 4, 201213 yr lol frogcase text me like wtf are they talking about? 7 cubes for 1 15? lol i have my zcon 18 in 7.5
September 4, 201213 yr 1 15 would be right at home in 4-5ft3 net volume with a moderate amount of port area and tuned to work with your application and goals.
September 4, 201213 yr I had mine in 5 cubes net with ~ 100 square inches of port area. If I were to do it again I would use a little bit less port area.
September 4, 201213 yr I had mine in 5 cubes net with ~ 100 square inches of port area. If I were to do it again I would use a little bit less port area.I bet that was super peaky and fell off super quick below tuning.
September 4, 201213 yr I had mine in 5 cubes net with ~ 100 square inches of port area. If I were to do it again I would use a little bit less port area.I bet that was super peaky and fell off super quick below tuning.It sure did, but it was loud as hell and moved some air
September 4, 201213 yr Author Thanks guys. I'll build a 5 cube box. Do you think the amp I'm going to run will be good or do you think there would be a better choice?
September 4, 201213 yr Thanks guys. I'll build a 5 cube box. Do you think the amp I'm going to run will be good or do you think there would be a better choice?That will be a great amp for it.
September 8, 201213 yr Author I will post pics when I start the project over the winter. Just because you asked nice
