September 12, 201214 yr Admin Where is the low pass set at?It appears it set it at around 200 hzI would suggest lowering it. Where is your high pass set for the mids?
September 12, 201214 yr Author Where is the low pass set at?It appears it set it at around 200 hzI would suggest lowering it. Where is your high pass set for the mids?around 100hz according to the dial.
September 12, 201214 yr Will sound so much better lowering the low pass to 80. I think at 100 that notes come through that shouldn't. Grab a good mid bass and you will have a much better overall sound. Good video
September 12, 201214 yr Author Will sound so much better lowering the low pass to 80. I think at 100 that notes come through that shouldn't. Grab a good mid bass and you will have a much better overall sound.Good videoI have a set of IA comps to put in plus deadener. Also that was only 3/5 volume not 80%. The neighbors might complain.
