Not the best song.Play the video after this one.
Envious of your dustcap.
Thanks!!
  • Admin
Where is the low pass set at?
It appears it set it at around 200 hz
  • Admin
I would suggest lowering it. Where is your high pass set for the mids?
around 100hz according to the dial.
Do you have the polarity reversed?
no I checked that.
Will sound so much better lowering the low pass to 80. I think at 100 that notes come through that shouldn't. Grab a good mid bass and you will have a much better overall sound.
Good video
Good video
I have a set of IA comps to put in plus deadener. Also that was only 3/5 volume not 80%. The neighbors might complain.
Video #2 bass test cd.
Do I need to turn the gain down?
