Posted October 14, 201213 yr Hey eveybody ive been doing a little research and ive narrowed it down to these two subs and cant decide which to go with as if now for electrical i have a yellow top under the hood and the big 3 done and will be adding another battery in the back probably xs d3100 and for the amp im planning on going with cresendo 2250 and its all going in a 1988 suburban not looking for numbers just a good loud daily sub.
October 14, 201213 yr Either will be great, flip a coin! Literally Both subs are amazing and with either one you can be proud to say you have one of the best subs on the market today.From a Customer service standpoint the Zcon hands down. My next build will be SSA Edited October 15, 201213 yr by swift
October 15, 201213 yr I don't have experience with the Fi, but I can say the ZCON has a very smooth response. I have my 18 tuned to 33hz and it hits hard on every song I throw at it. I'm thoroughly impressed by the ZCON.
October 15, 201213 yr I do believe the Lineraty? of the sp4 is extremely impressive. The zcon can take gwaps of power, and put up some godly numbers. Mark/Aaron have also had amazing CS. You can really flip a coin.
October 15, 201213 yr You won't be disappointed with either. I do agree that it is nice that Aaron is on here pretty much everyday answering questions, and addressing any issues.
October 15, 201213 yr They both are great subs. I had a pair of 15's of each and the only difference was the sp4s were 1 db louder. Or as equal as i could make it. They both sound great everything else was pretty much even. Edited October 15, 201213 yr by liljestrand
October 15, 201213 yr Admin They are two different sub woofers, as the design is fairly different. But, they are meant for similar end goals. The SP4 does have more coil surface, and the option for a spaced spider, so it is able to handle more then the Zcon. Either way, it is a win win.
October 15, 201213 yr Admin what is a spaced spider?There is an additional spider placed on a different landing on the basket. This can help with possible coil rock at extremely high levels, as the basket the SP4 uses has a ton of clearance. The SP4 does not have a coil rock issue, but for a metaphor; think about a po-go stick as your jumping up and down, it is more stable when both your hands and feet are on it, compared to just your feet.
October 15, 201213 yr The SSA nuthuggers will recommend the zcon.Huge differences between these two subs. Premature to recommend one over the other with the information you provided.
October 15, 201213 yr what is a spaced spider?There is an additional spider placed on a different landing on the basket. This can help with possible coil rock at extremely high levels, as the basket the SP4 uses has a ton of clearance. The SP4 does not have a coil rock issue, but for a metaphor; think about a po-go stick as your jumping up and down, it is more stable when both your hands and feet are on it, compared to just your feet.no kidding? I saw this feature on another brand sub woofer. I was very impressed. I'm glad to see others doing the same. But come to think about they use like baskets.
October 15, 201213 yr Popular Post The SSA nuthuggers will recommend the zcon.Huge differences between these two subs. Premature to recommend one over the other with the information you provided.nothing wrong wt a lil brand loyalty.
October 15, 201213 yr Hey man my buddy has both of those he is trying to sell, Message Dictator or me later bro save some money! they both are great subs
October 15, 201213 yr Admin Popular Post The SSA nuthuggers will recommend the zcon.Huge differences between these two subs. Premature to recommend one over the other with the information you provided.nothing wrong wt a lil brand loyalty. Exactly, difference between us and most, is we do not have nut huggers, we have return customers.
October 15, 201213 yr what is a spaced spider?There is an additional spider placed on a different landing on the basket. This can help with possible coil rock at extremely high levels, as the basket the SP4 uses has a ton of clearance. The SP4 does not have a coil rock issue, but for a metaphor; think about a po-go stick as your jumping up and down, it is more stable when both your hands and feet are on it, compared to just your feet.no kidding? I saw this feature on another brand sub woofer. I was very impressed. I'm glad to see others doing the same. But come to think about they use like baskets. i few other company's have too... just to name one off the top of my head the LMS ultras were like that,
October 15, 201213 yr Author Yea im going with the zcon i just have to sell my gcons and i will be ordering the zcon!
October 15, 201213 yr The SSA nuthuggers will recommend the zcon.Huge differences between these two subs. Premature to recommend one over the other with the information you provided.If one of the options was Sundown, you would have chosen it
