Posted January 31, 201313 yr Looking into getting an ssa woofer.. Found a v1 xcon for good price, would like to now the differences between the v1 and v2 xcons....Any body have the t/s from the v1 woofers ???
January 31, 201313 yr Small upgrades, nothing to change t/s specs really. I believe it's mostly in the cooling aspect.
January 31, 201313 yr Author Small upgrades, nothing to change t/s specs really. I believe it's mostly in the cooling aspect.Ok that's what I wanted to hear.... THANKX
January 31, 201313 yr Author Been using a Q for a few years, time to update a lil. LolLove the flat cone look of the xcons...
January 31, 201313 yr i think it may be the spiders aswell. not 100% wait for mark or Aaron to confirm
January 31, 201313 yr Yeah the V2s have different cooling, and they recently switched to nomex spiders. When I was looking at mine Aaron said that I wouldn't have any issues running a V1 and a V2 in the same enclosure, so they are that similar.
January 31, 201313 yr Yeah the V2s have different cooling, and they recently switched to nomex spiders. When I was looking at mine Aaron said that I wouldn't have any issues running a V1 and a V2 in the same enclosure, so they are that similar. That's exactly what I was wondering also. Thanks.
January 31, 201313 yr Admin The original has a vented pole, the new model has a solid, axial CNC machined pole.
January 31, 201313 yr The original has a vented pole, the new model has a solid, axial CNC machined pole. :)/> What advantage or disadvantage would the OP have if he used both together, if any?
February 1, 201313 yr Author The original has a vented pole, the new model has a solid, axial CNC machined pole. :)/>So how much room should I leave behind the motor?? Mite be an issue with my install box requirements....
February 2, 201312 yr Admin The original has a vented pole, the new model has a solid, axial CNC machined pole. :)/>/> What advantage or disadvantage would the OP have if he used both together, if any?One is a tiny bit more efficient, the other can take a little more thermal. The difference is inaudible and might only be noticeable in extreme levels.
April 28, 201312 yr The soft parts should fit fine, but you wouldn't be physically changing the motor to a v2.
April 29, 201312 yr The soft parts should fit fine, but you wouldn't be physically changing the motor to a v2. do you mean can put all the parts that come with the recone in, but the sub still remains a v1?
April 29, 201312 yr The soft parts should fit fine, but you wouldn't be physically changing the motor to a v2.do you mean can put all the parts that come with the recone in, but the sub still remains a v1?Yes.
April 29, 201312 yr The soft parts should fit fine, but you wouldn't be physically changing the motor to a v2. do you mean can put all the parts that come with the recone in, but the sub still remains a v1? Yes it is a V1 motor. The recone is only the coil and soft parts which are very similar to the v1 anyway.
April 29, 201312 yr The soft parts should fit fine, but you wouldn't be physically changing the motor to a v2. do you mean can put all the parts that come with the recone in, but the sub still remains a v1? Yes it is a V1 motor. The recone is only the coil and soft parts which are very similar to the v1 anyway. sorry for thread jacking u guys. but quick question. what parts come in a recone? Edited April 29, 201312 yr by 1two3
April 29, 201312 yr sorry for thread jacking u guys. but quick question. what parts come in a recone? All the soft parts and the VC : I've always saw the recone kits in just one piece.Use google / pictures or take a look at the store pics, maybe.
April 29, 201312 yr sorry for thread jacking u guys. but quick question. what parts come in a recone?All the soft parts and the VC : I've always saw the recone kits in just one piece.Use google / pictures or take a look at the store pics, maybe.Even better idea, thanks
