February 6, 201313 yr Author I just purchased 2 E8v3's d4 My budget is as low as possible. I had a SA-12 before and decided I wanted to join the crazy 8's craze. I'm building a box for the subs. So far I settled on 1.5^3 ft tuned @ 35 hz using 2 2" aero ports. I figured after dis I would be closer to 1.2^3 ft. Any suggestions will be appreciated. They are going in a Mazda 6.
February 6, 201313 yr Any amp that does rated rms power at 1 or 4 ohms, considering you gave no budget its hard to make a suggestion for ya.
February 6, 201313 yr Author My bad. My budget is under $250. I know they're rated at 300 watts rms. I can't decide if I want to run @ 1 or 4 ohms. Also does running @4ohms yield improved sq. Again sorry for leaving out the budget. The amps I am considering are the MB Quart Ref1.800 and Hifonics Brutus 1700 or 2100.
February 8, 201313 yr Author Well the subs came today. Honestly can't see how these are considered entry level. Any suggestions from some experienced people would greatly be appreciated.
