  • Replies 62
  • Views 6k
  • Looks like our new projects will parallel each other Rick...Will be trading in my gcon for ricks xcons and redoing my front stage to run active. Finally got some real pics and ditched the cardboard dr
  • I love sq but sometimes I get in these modes where I am just craving spl. I was going to port the xcons for sure but you are making me seriously consider running them sealed Neal
  • I am very similar, low levels it must sound good. Then the urge to make people shit their pants kicks in. Almost like building Haunt props suttle and unsure at first, then BAM coming at you to scare t
  • Admin
Dog with SSA sub pictures are required here. ;)
That's my three legged helper!
  • 2 weeks later...
Ok more progress! For every step I complete I find something else that needs attention but here we are so far
First time working with anything other than mdf. I liked the look of the wood so I wanted to show it off
A little Sundown power for my front stage
And an AQ for the xcons
Laying everything out
I am liking the new setup but I am struggling with securing the box in my trunk. I've never had anything this heavy in my trunk before and no carpet makes it slide even easier. All these little install details that I neglect to plan for show my inexperience and make me realize the learning curve is steeper than I thought it was.
  • 4 weeks later...
Mounted...
Snug in their new home!
Final load...
Don's velcro is always handy to have laying around. Your never know when you will find another use for it.
ca15271c-5d1f-41a0-b2ef-020202af575b_zps
A look from the inside
All cleaned up and ready to go ;)
e0e20877-c279-410e-8eb0-5c164ec05388_zps
I decided to use the holes from my previous setup to run power and ground wires to save time/money. Not quite as clean but an acceptable compromise.
love the progress, looks awesome man, always happy to see someone enjoying their projects.
Liking the stained wood as well.  Definitely different from the normal grey carpet.
And as for using the pre-existing holes for the wiring, it's fine, you've kept them neat and tidy, and ziptied together.  Nothing wrong with that.
Looking good
Looking good
Thank you. LOVE the xcons! Next step is to seal the rear deck where the 6x9's used to be and glass my tweeters into the a pillars
Should varnish that box a couple times give it a sexy mirror finish on it
