May 10, 201313 yr How do you know it is the rca cable that is faulting? Do you check them with a dvm?No but when one side goes out ill switch them around and it will just be one side not working..... not sure about the sound. . When there would be weird sound coming through lets say on my tweeters if I faded them out on my eq there would be a staticy/poping sound still... but then I unhook the rca and it goes away......... then ill get a new set of rca's and it will be cool for a little bit...... I have been working in my trunk a while and unhooking and hooking them up alot How do you know it is the rca cable that is faulting? Do you check them with a dvm?No but when one side goes out ill switch them around and it will just be one side not working..... not sure about the sound. . When there would be weird sound coming through lets say on my tweeters if I faded them out on my eq there would be a staticy/poping sound still... but then I unhook the rca and it goes away......... then ill get a new set of rca's and it will be cool for a little bit...... I have been working in my trunk a while and unhooking and hooking them up alot Cant say for sure it is your rca's without checking them. You should have zero resistance from one rca end to the other (neg to neg or pos to pos). Sure it isn't your amp?
May 10, 201313 yr Author Its been happening with a couple amps. I just got the 300/4 and it was happening with my last amp. It seems like its only after I take everything out of the trunk to do some kind of fitting for my new box. . Ill hook everything back up and something will sound funny
May 10, 201313 yr Author weird........ could be your cd player....I was just thinking that. Cause It has taken a beating lol. With my last setup when the bass would hit hard the screen on the Cd player would go in and out alot. Mite go get an "rca to aux" wire and try just hooking my mp3 player up right to my eq and see if that makes any difference. Kinda tight on money so wont be able to get a new Cd player for a little bit.... most of this build has been extra pieces of wood from boxes iv built lol Edited May 10, 201313 yr by frogcase2002
May 10, 201313 yr Author Well subs are ready and box is just about ready to start putting together inside the trunk
May 10, 201313 yr Author O and by the way I think it was the amp this time. I think one Chan. Is out on the 300/4. . Tryed moving rca's around and then tryed each Chan on the amp separately and one Chan makes speakers sound funny. Like The the sound of moving around the needle on a record Lol if you know what I'm sayin
May 10, 201313 yr Author Going to have 6 baffles lol. 4 behind the subs and 2 "flush mount" . So I can have the front of the box pretty much right up against the fold down seats and there wont be a chance on them hitting the seats if the thay happen to be up sometime
May 11, 201313 yr Author All 4 coils reading 1.6 . Bout to go hook up/test the new one I just reconed and make sure everything is cool
May 11, 201313 yr Shouldn't worry about deadening if I'm doing a trunk wall right?It won't be as important to deaden the trunk, but I wouldn't skip deadening/sealing the front doors.
May 12, 201313 yr Author Shouldn't worry about deadening if I'm doing a trunk wall right?It won't be as important to deaden the trunk, but I wouldn't skip deadening/sealing the front doors.That's already done just wasn't sure about the trunk. Figured I wouldn't need to if its going to be sealed off
May 12, 201313 yr Shouldn't worry about deadening if I'm doing a trunk wall right?It won't be as important to deaden the trunk, but I wouldn't skip deadening/sealing the front doors.That's already done just wasn't sure about the trunk. Figured I wouldn't need to if its going to be sealed offStealing your baffle idea for the camry. Yoink!!
May 12, 201313 yr lookin good,. i wish this was an option for me!It has me thinking about a new build....even though I still have stuff laying around for my current build.
May 12, 201313 yr Author lookin good,. i wish this was an option for me!Could you do maybe a 4th order bandpass ported into your cabin? Or 6th
May 12, 201313 yr lookin good,. i wish this was an option for me!Could you do maybe a 4th order bandpass ported into your cabin? Or 6thNope, that puts you into mod classes if I'm not mistaken.
May 13, 201313 yr Author Well time to build it all In the trunk ill try to get some pictures up later.
May 13, 201313 yr Admin Shouldn't worry about deadening if I'm doing a trunk wall right?It won't be as important to deaden the trunk, but I wouldn't skip deadening/sealing the front doors.That's already done just wasn't sure about the trunk. Figured I wouldn't need to if its going to be sealed offStealing your baffle idea for the camry. Yoink!!
