May 21, 201510 yr Solid, solid like a rock. That's a nice looking foundation my friend, and sucks to hear plus see the condition of those recones.
May 21, 201510 yr Author Im hoping they will be ok. Just sucks how bad the surrounds were bent up. . Iv ordered recones from ssa before and were packaged alot better than thay were this time
May 21, 201510 yr Author Solid, solid like a rock. That's a nice looking foundation my friend, and sucks to hear plus see the condition of those recones.I built the frame of the wall like 3 years ago lol. Finally getting around to finishing it. Its really really solid
May 21, 201510 yr Im hoping they will be ok. Just sucks how bad the surrounds were bent up. . Iv ordered recones from ssa before and were packaged alot better than thay were this timeCould of at least sent you some stickers or a shirt or something. You waited patiently for a LONG time. Then they were just crammed in a small box. I can't believe they aren't in worse shape.
May 21, 201510 yr Cut a MDF ring out to fit the surround landing,an clamp it after glue to insure it lays down good
May 23, 201510 yr Author You tried gluing them down yet?Not yet. . Need to order ca glue. . And waiting for the surrounds to look normal
May 28, 201510 yr You tried gluing them down yet?Not yet. . Need to order ca glue. . And waiting for the surrounds to look normalLet me know when your about to recone i want to stop by when you do
November 9, 201510 yr Author Doing a crazy budget build in the sable right now as im waiting to get everything for my van build . Got pretty much the cheapest mids highs and sub from parts express. Spent under $50 for 4 6.5s , 2 tweeters and a 12" sub . . I have the mids and highs installed now and I must say im pretty impressed . Got them in an active 2 way setup . . Its crazy how the install and crossover points can make about the cheapest speakers you can find sound pretty dam good.Ill start posting pictures once I start on the enclosure for the sub. . Should have under 200 bucks in 4 mids, 2 tweeters, 12" sub and either a 5 channel or a 4 channel and mono. . . If anyone has any suggestions on the amp or amps I could use let me know. . Looking to spend less than 150 on amp/amps to keep everything together less than 200
November 16, 201510 yr Author Was looking at that one but just a little higher than i wanted to spend . Mite end up getting it though . Was leaning towards the ppi BA2200.5
January 30, 201610 yr Author Should be getting the van build stated soon. Anyone got suggestions on batts to get that are reasonably priced new?
January 30, 201610 yr Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 323Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 326Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 327Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 328 Should be getting the van build stated soon. Anyone got suggestions on batts to get that are reasonably priced new?Ryan from Ram Designs has NSB170FT's for a great price, I'll be picking up 4 myself. I think he wants like 200 each for them...
January 30, 201610 yr Author How would I get in contact with him? . . I seen some of them for sale on caraudio.com but says there all sold
February 4, 20169 yr Author Got 3 power and 3 ground runs ran in the van and installed the new alt. Ill start a new build log for the van once I start on the enclosure for the wall
February 4, 20169 yr Author Is it fine just doing one run from alt to batt when having multiple runs from front batt back to rear batts since its a short run?
February 5, 20169 yr Author Need help building?If you wanna come by when I get the wood. . Will be this month sometime. Probably a couple weeks
February 10, 20169 yr Need help building?If you wanna come by when I get the wood. . Will be this month sometime. Probably a couple weeksI'll help. Need me to bring any tools?
