Posted June 25, 201312 yr For 4/0 terminals.. what provides a better, long lasting connection for what it's worth? There is a big price difference here and i'm fine with buying a hydraulic crimper but i hear that a hammer crimper is just fine. But how fine is it? I will probably be crimping around 250 terminals. What is the more logical choice between the two to purchase?
June 25, 201312 yr I dont have any input on 4/0 wire, but I know for my 1/0 I used a friends hydraulic crimper for my first time around, then the 2nd time wiring my Jeep I used a $20 hammer crimper off amazon and both ways were sufficient, couldnt pull the terminals off if I wanted to.Main difference was the hydraulic crimper was a bit easier to use. Edited June 25, 201312 yr by DanP
June 25, 201312 yr I never used a hammer crimper. I believe that a hydraulic crimper would be easier to use. Price wise the hydraulic crimper maybe more expensive. I think i bought mine at Harbor Freight for ~$20.00. I never had any issues with mine and have had it at used it for years.
June 26, 201312 yr my hammer crimper has helped me make a few hundred K and I've not one lick of trouble
June 26, 201312 yr Author what should the terminal look like or how many times do you hit it with a normal hammer before it's "secure"?
June 26, 201312 yr Author no i mean what shoudl the terminal look like to know it's been hammered right? I typically vice my terminals and then punch them afterword. Some of those terminals still got loose which had me leary about using a hammer crimper since the punch n vice were unsuccessful on some of my last batch i did.
June 26, 201312 yr all you gotta do is beat the shit out of it. A loooooong time ago I had a customer fuck around with my install and the power wire got wrapped up in the front tire on a f150. The wire wound up ripping the battery post off the battery.
June 26, 201312 yr I have a hammer crimper I got mine from Temco on ebay for like $17.00 I like it better than soldering 1/0 with a propane torch. I imagine a hydraulic crimper would be a lot better but it costs more too.
June 26, 201312 yr i would say that propane and some solder would be alot cheaper. Just come up with a vice mechanism that can hold multiple tips...lol... tips and go down the line.. But if your set on a crimper..I have no idea, i just have a big ass hammer called Molly Mall
June 26, 201312 yr I used that exact crimper on my last install. Faster than soldering and it held strong. My dad has had one for 20+ years and swears by it.
June 26, 201312 yr I've owned both. I like my hydraulic crimpers a lot. I would definitely send the coin again. I would stay away from the HF ones, they barely fit 1/0. Hammer crimpers are great on a budget but you can't use them in a car
June 26, 201312 yr Only gripe i have about my 8 ton from HF is the size of the dies supplied with it. using copper 1/0 lugs i had to use the die labeled as 00. Be sure to check how large of a terminal can fit with that 4/0 wire.
June 26, 201312 yr That is going to be a lot of hammering on ~250 pieces. For that large amount personally I would buy a hydraulic crimper.For smaller amounts like a single build > solder or hammer.
June 26, 201312 yr I used my hammer crimper for years and loved it until a few months ago when I smashed my thumb, threw it away after that. Looking to get a hydraulic one soon.
June 26, 201312 yr I used my hammer crimper for years and loved it until a few months ago when I smashed my thumb, threw it away after that. Looking to get a hydraulic one soon.I have one but it sucks on the bigger gauges. Its like they didnt make the dies the right size.
June 26, 201312 yr I actually use a framing hammer. That is it.I have even skipped using an anvil and just hammered against concrete. I had to do it before when making a cable for welding and it worked. It wasn't pretty but 4 men couldn't pull the wire from the terminal so we called it good. I was suprised the copper itself didn't give with that much tension. Edited June 26, 201312 yr by dem beats
June 26, 201312 yr I used my hammer crimper for years and loved it until a few months ago when I smashed my thumb, threw it away after that. Looking to get a hydraulic one soon.I have one but it sucks on the bigger gauges. Its like they didnt make the dies the right size.Sounds like a personal issue, never had an issue with bigger gauges.
