Posted September 12, 201312 yr The sa12s are rated at 600rms but i have seen they can take more. My question is can i safely run two sa12s on the saz1500 at 1 ohm in a daily setup?
September 12, 201312 yr The sa12s are rated at 600rms but i have seen they can take more. My question is can i safely run two sa12s on the saz1500 at 1 ohm in a daily setup?Sure if you set the gain right subsonic filter and do it without bass boost. Headroom is a good thing to have.
September 12, 201312 yr I run 2 sa12s on a saz1500 in my 2011 Malibu. No problems here. Set gain by ear and crank on it hard every day. Can't say for certain that you will have the same results but it works for me
September 12, 201312 yr I've been running a single SA12 on a SAZ1500D for an year and a half, no problem. Once I had fuse problems so my second battery was not charging good and my amp clipped due to low voltage. Sub got hot and smelled, but no damage. Two would love it daily.
September 12, 201312 yr I'm running my SA-12s on a SAZ2500D @ 1ohm. Just gotta be smart with it lol. Edited September 12, 201312 yr by grayta
September 12, 201312 yr Author so if my amp does not clip i shouldnt have a problem? on 1 ohm that is
September 12, 201312 yr so if my amp does not clip i shouldnt have a problem? on 1 ohm that isOn any ohms. Set the gain up for 1200wrms and some songs will play louder some won't because they are recorded. You won't hear the difference between 1200 and 1500wrms with your ears.
