Posted October 12, 201312 yr I need help creating a product list for Direct Speaker Supplies to carry. I already have just about everything to recone subwoofers on its way. The problem is I have accounts with just about every distributor you can think of and combined they have tens of thousands of parts. So I'd like to know if there is a special item that you would need. Maybe something no one else carries or they do and it's just too expensive. For example maybe you would like to purchase the really nice high nap carpet I use on my enclosures. Give me a list of what you think would be priority, that must have hard to get item. NOTE I WILL NOT BE CARRYING ANY PRODUCT LIKE AMPS OR SPEAKERS (BESIDES DSS BRAND), ONLY SPEAKER PARTS AND INSTALLATION SUPPLIES.
October 12, 201312 yr DSS distro blocks. Flexible ones. Like (2) 1/0 in and out, with (2) 4awg in and out. For 3 or 4 amp installs. **Flexible meaning multi-application, not like those weird JL ones that the wires can move. Edited October 12, 201312 yr by gprestonmoto
October 12, 201312 yr heat shrinktechflex both in either normal, exotic or uv colors. cheap enough heat gun for it if you do butt connectors, i'd say get the ones that solder the wires together.. Everybody has a local shop that sells connectors cheap already. Stocking those would be different to many people that have never heard of them. aero flares and\or pipes? set screws for amps allen wrenches for amps The extremely cheap $1-3 china volt meters soldering iron with proper solder and flux Material used for properly reconing that is not given with a recone(IE- centering the former, etc..) flexible conduit. I use it to run cable under the car. Might be a bish to ship though.. tap and die set crimpers for small and large terminals.
October 12, 201312 yr Lower cost yet proper flex and strand count wire, and install kits (hu, amp etc).Also what about recones for hard to find speakers?J
October 13, 201312 yr Author Lower cost yet proper flex and strand count wire, and install kits (hu, amp etc).Also what about recones for hard to find speakers?J Lower cost yet proper flex and strand count wire, and install kits (hu, amp etc).Also what about recones for hard to find speakers?JI have been looking at ordering good quality solid copper wire akin to XS power or welding cable. This will take a while to get however I have accounts with metra and AMMP that carry good quality wiring that does not have MAP pricing. I will be taking Amazon's approach with pricing. Keeping profit at bare minimum to increase sale volumes. I am also using USPS flat rate shipping so every thing will have shipping in the price already. Below are current prcing on some cones that are on the site. 10'' cone: 1) $27.99 2) $20.99 4) $17.99 6 or more $15.99 18'' cone: 1) $46.99 2) $37.99 4) $33.99 6) $31.99 again these prices include shipping.
October 13, 201312 yr Perhaps a 'build a speaker kit' with say 5 different motors, 3 different basket designes, 2 different coil structures per motor, 4 different impedences.Do it as a learning experience, as people are more apt to try reconing on a higher end sub if they try a few 'lower quality' subs first.J
October 13, 201312 yr Author Perhaps a 'build a speaker kit' with say 5 different motors, 3 different basket designes, 2 different coil structures per motor, 4 different impedences.Do it as a learning experience, as people are more apt to try reconing on a higher end sub if they try a few 'lower quality' subs first.JThis is a really good idea however due to the small margins I keep on product it really wouldn't be cost effective for the customer. The actual assemble cost on my Ethos for example is only about $15 and I don't add profit to that. Shipping the motor separate from the other parts would make the speaker more expensive than it already is. The only other way would be to find a clever way to get all the parts in one box without the motor from destroying the other parts
October 13, 201312 yr Author I'd love to see some gap fill CA glue come in at a great price.already got you covered on that. It is black however. Same as used on my drivers. Really good quality. Compared to Hernon Manufacturing
October 13, 201312 yr Author heat shrink getting some 100 foot rolls of verious sizestechflex both in either normal, exotic or uv colors. cheap enough heat gun for it gotta get price on heat gun. Still searching for a heat knife if you do butt connectors, i'd say get the ones that solder the wires together.. Everybody has a local shop that sells connectors cheap already. Stocking those would be different to many people that have never heard of them. I've never seen these. I do have some solid copper ones in 8,6,4,2 gauge that you crimp, add your own solder, and then can heat shrink over them. aero flares and\or pipes? Have access to 2,4,6 inches. Need to verify that they can use standard pvc pipe though. set screws for amps shouldn't be a problem. Allen and screw headallen wrenches for amps The extremely cheap $1-3 china volt meters I could get stinger one's. In not sure if a cheaper made meter's refresh rate would be quick enough soldering iron with proper solder and flux on its way Material used for properly reconing that is not given with a recone I'll be carry glue, solder, flux, flap discs and other thing to remove glue. best thing for shimming coils is copy paper(IE- centering the former, etc..) flexible conduit. I use it to run cable under the car. Might be a bish to ship though.. Like flexible rubber/plastic undergound wire conduit for houses tap and die set crimpers for small and large terminals. I can get several styles for small speaker wire connects and a large bolt cutter style for power wire.
