August 6, 201412 yr Author Frogcase2002 ( Casey) help me out and made some baffles for me Cut the stock grill out
August 6, 201412 yr Dam didn't see them once you put the panels back on. Looks like they fit perfect!
August 6, 201412 yr Frogcase2002 ( Casey) help me out and made some baffles for me Cut the stock grill out That looks familiar... and real good! The second gen S10 doors have to be the easiest I've ever built baffles for so far and so easy to remove the factory grills on too. The entire thing looks great man!
August 6, 201412 yr Author Frogcase2002 ( Casey) help me out and made some baffles for me Cut the stock grill out That looks familiar... and real good! The second gen S10 doors have to be the easiest I've ever built baffles for so far and so easy to remove the factory grills on too. The entire thing looks great man! Thank you, I did look through your build log that where I got the idea at,I still plan on painting the baffles and probably adding some grills also but that will have to wait till next weekend because I'll be at a comp this Saturday.
August 9, 201411 yr Author Went to a comp today in Dayton it was both Meca and Iasca. I got first place s2, first place db1,3rd place bass boxing, 4th place idbl,and I also got phat truck.
