Posted May 3, 200619 yr I bought 2 15" RLP D4's a couple months ago and finished installing them in my Nissan Titan last weekend. The subs and ports are both firing upward in the cab. I have them hooked up to an elemental designs ed 9.1 amp at 1 ohm. I set the gains using a -3dB 50hz sine wave and set the output to 34.64 VAC which equates to 1200watts. The subs are in separate 2.75ft ported boxes tuned to 29Hz with 30 square inches of port area. The problem I am having is the subs dont get loud at all even though they have alot of excursion. My brothers system (in an S-10) which is 2 old sounstream spl 12's in sealed enlosures running off of a kicker kx350 blows mine away. I have an Alpine IVA-D310 head unit and have also ran the subs off of my brothers head unit which didnt make much difference. I know its not a power issue because I have a 200amp alternator and have done the big three in 0 gauge. Ive tried everything to get them to get louder but nothing helps. I thought I would sign up here and see if you guys had any more suggestions. Thanks
May 3, 200619 yr Check the phase on the subs. Might have one out of phase with the other.Porting them to the floor would have been a better choice unfortunately.
May 3, 200619 yr Author I pulled the subs out of the boxes and checked the wiring with a DMM. Everything is hooked up correctly. Does having the ports and subs pointing up kill some of the output?
May 3, 200619 yr Try switching the polarity on one of the subs. Checking with a DMM doesn't do too much
May 3, 200619 yr with 29hz tuning frequency and that box size with that port area, I take it the lenght of your port is 30" in each subwooferIs that the case?
May 3, 200619 yr Author ANeonRider, you are the best. I changed the polarity on one sub and it works great. The neighbor kid came running over to my house saying he could hear the subs in his house across the street with the doors closed and my garage door was closed too! Thanks for your quick reply!!
May 3, 200619 yr ANeonRider, you are the best. I changed the polarity on one sub and it works great. The neighbor kid came running over to my house saying he could hear the subs in his house across the street with the doors closed and my garage door was closed too! Thanks for your quick reply!!<{POST_SNAPBACK}>Not a problem, what we are here for. Now, boom responsibly.
May 3, 200619 yr you should get a battery (like a D size) and hook it up to the speaker wire + to + and - to - and make sure both of your subs arent out of phase. that happened to me. when you put the battery on the speaker the speaker should move out slightly, if it moves in switch the wire on both of the subs.
May 3, 200619 yr Author Thats a good idea. I dont know why one sub was out of phase with the other. I hooked it up in a 1 ohm config which meant all of the positive terminals would be tied together same with the negatives. I guess something was mismarked. The only other thing i could think of is the nine.1 is 1 channel but has two positive and two negative speaker terminals that are tied together internally to make it easier to hook up two subs and I guess one set could have not been marked right.
May 3, 200619 yr your first guess has to a mismarked terminal is probably the case. it happens quite a bit. whenever i install subs i always check polarity with a "speaker popper". (9 volt battry with speaker wire leads) . one more then one occasion i had happen to me exactly what you're talking about. wire everything up, double check it. no output. change polarity..BOOM! it happens bro.glad it's fixed!!! so now your getting output, how about a short review?wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 3, 200619 yr Admin scott for the win!!!anyway welcome to SSA and do you have any pictures of your install?
May 4, 200619 yr Author All I can say is wow! These things are loud. The bass is very clear even at full volume. I really didnt know what to expect from these except for reading the forums but I'm glad I bought them. I'll recommend them to anybody I know whos looking for new subs. Anyways here are some photos of the install in my Nissan Titan. I'm running -2 RLP15's 2.75ft each @ 29Hzedi 6500 component setElemental Designs nine.1 and nine.2xAlpine IVA-D310 lcd screenIraggi 200amp alternatorOptima Red TopBig Three in 0 gaugewhole interior sound deadened with edead v1se2
May 4, 200619 yr Author Thanks for the comments. It took alot of work but was well worth it. Now all of my friends are jealous lol!
May 9, 200619 yr geez... that's not excessive does it own your brother's system now or what? Edited May 9, 200619 yr by ighettoboyi
May 10, 200619 yr you should get a battery (like a D size) and hook it up to the speaker wire + to + and - to - and make sure both of your subs arent out of phase. that happened to me. when you put the battery on the speaker the speaker should move out slightly, if it moves in switch the wire on both of the subs.<{POST_SNAPBACK}>Great tip wit the battery thing, we do this at work a lot. I can't believe we let that out the door, but it happens. We must soldered the terminals on the wrong side of eachother. No harm done, but the colors are backwards from your other speaker. Its easy to do because the voice coils are not color coated or anything, and neither are the spider leads so its a matter keep the red on the left and black on the right. I'm guessing in your case it was reversed?In anycase, the the red wire should goto the left ternimal adn the black to the right. MAke sure you have it like that on both subwoofers. Right now you either have it like that or reversed. If if its reversed, your subwoofers will be out of phase with your car speakers. Not a huge deal but it will cause a bit of a gap in the crossover. So double check! Again, I'm really sorry about that, we shouldnt fudge up like that period! Edited May 10, 200619 yr by 7
May 10, 200619 yr Author Oh yea, it destroys my brothers system. I'll have to take the subs out and check them with a battery when I get home just to make sure everythings hooked up right. I got the edi6500's hooked up last weekend and they sound great.
May 10, 200619 yr nice work on th' box.drywall screws 4tw and you need a bigger amp im pretty sure with 2 or 3000 wrms in there you could make yourself puke on a daily basis with low end madness. Edited May 10, 200619 yr by 60ndown
