I have pmed you.  Our normal pricing will be posted publicly when we start the group buy this month.
Will you please pm me the pricing too? Thank you.
  • Replies 58
  • Views 22.1k
  • Heisenberg i can show you the guts of my hd8000 LOOKS can be very deceiving b/c ppl are so use to korean guts. was  3-400watts short at 12.6 but over was well over lol
  • Unless you are an electrical engineer and also have the accompanying schematics, then pictures of any amp are meaningless. People on the internet like to ooh and ahh over pics, but 99.9% of the membe
  • I love amp-guts. they get me to sleep at night.
Is repair on these going to be a headache?
IE shortage of parts, 1 or 2 companies only willing to repair ect?
Well, I can tell you that most companies only use 1 authorized repair center.
Once the warranty is up, that's when people have ability to choose wherever.
we have been at "war" with customer support for expanding potential repair centers.
As of right now, it's to be determined...
There is no shortage of parts or should never be the case as we do not plan on stocking their rare products like the high voltage line.
We will of course announce any changes as they become available
on a side note, the HD line is about to have its first multichannel amp as well. More details soon.
Wow if the group buy is alot cheaper then the price on that site Julian posted I will definitely order and wait until march to get it but if it's only 20 dollars are so I think I'm going to go ahead and jump on it I can't stand waiting
The waiting is some people's issue which i can understand.
Our sales come with accessories that are needed that no one else supplies.
Factor the cost of these into the already lower group buy price and see how much cheaper it is.
Yeah that's what I was thinking about how the 8000 watt amp was gonna get fed with that one set of small terminals so I guess I'm just going to have to suck it up and wait
Here are the specs of the first multichannel amp in the HD Line-
All rated at 13.8v @0.02% THD
4x33w @8ohm
4x60w @4ohm
4x100w @2ohm
2x200w @4ohm
2x120w @8ohm
2x66w @16ohm
2x100w + 1x200w @2ohm
2x60w + 1x120w @4ohm
2x33w + 1x66w @8ohm
X-over Fixed HPF\LPF- 80Hz
Weight- 1.4lbs
Dimensions-
LxWxH
8" x 6" x 2"
Here is a pic of it-
I haven't asked for pricing yet but I'll get it once the group buy starts.
It literally just started to be sold.
Will there be any higher powered models, like 100w or greater x4 @ 4ohms?
Taramp's does offer higher powered multichannel amps.  Just not in the HD line.
The largest multichannel amp currently manufactured is the 1200x4 and 1300x2.
The 1200x4 is rated as follows-
- Pot. Max. @ 13.8VDC (1 OHM) - 1440 W RMS (4x360W RMS)
- Pot. Max. @ 13.8VDC (2 OHMS) - 950W RMS (4x237W RMS)
- Pot. Max. @ 13.8VDC (4 OHMS) - 522 W RMS (4x130W RMS)
- Pot. Max. @ 12.6VDC (1 OHM) - 1200 W RMS (4x300W RMS)
- Pot. Max. @ 12.6VDC (2 OHMS) - 792W RMS (4x198W RMS)
- Pot. Max. @ 12.6VDC (4 OHMS) - 435 W RMS (4x109W RMS)
- Pot. Max. in Bridged @ 13.8VDC (2 OHMS) - 1440W RMS (2x720W RMS)
- Pot. Max. in Bridged @ 13.8VDC (4 OHMS) - 972W RMS (2x486W RMS)
- Pot. Max. in Bridged @ 12.6VDC (2 OHMS) - 1200W RMS (2x600W RMS)
- Pot. Max. in Bridged @ 12.6VDC (4 OHMS) - 810W RMS (2x405W RMS)
- Bass Boost (Channels 3 and 4) - 0 to 10dB (50Hz)
- Input Sensitivity - 160mV (With the Level to 100 % .)
- Total Harmonic Distortion (THD) - > 0.5%
- Separation between Channels (Crosstalk) - > 45dB
- Signal-to-Noise Ratio - > 90dB
- Damping Factor - 350
- Frequency Response (Full Range) - 20Hz to 30kHz (-1dB)
- Crossover:
H. P. F (High Pass Filter) - Fixed 100Hz (-12db/ 8nd )
L. P. F (Low Pass Filter) - Fixed 100Hz (-12db/ 8nd)
- Input Impedance - 18k OHMS
- Protection: Short on the Output and Supply Voltage High / Low -
- Minimum Supply Voltage - 10VDC
- Supply Voltage Maximum - 16VDC
- Consumption at Rest - 1.80 Amp.
- Cons. Maximum Musical @ 12.6VDC - 65 Amp.
- Cons. Maximum with Sinusoidal Signal (1KHz) @ 12.6VDC - 130Amp.
- Dimensions (WxHxD) 7.68" x 2.2" x 14.25"
- Weight - 6.06lbs
That is the 1ohm version.  You can also get it in the 2ohm version.
The 2ohm version would be same price and all power ratings are shifted up, 2, 4 and 8ohms.
Odd. I'm testing an HD3000 right now in my truck for my Rockford Rep.
He's considering picking them up to sell them. I like it so far. Would love to test one of their larger amps.
Sounds like you're staying on top of everything Shizz. I love the power that 4ch is putting out. That could really help guys with tight installs.
Hurry your ass up with the group buy!
Any pics of the 1200x4, those ratings are nice and the 1 ohm version would be perfect.
Yeah, I'll take a HD8k & 1200x4 please :)
1200x4-
Hd400.4s group buy pricing will be under 190 shipped
Just me or that 1200x4 looks a bit like some Sound Digital amps from Brazil? Color scheme and heatsink.
How the... Lol
Just picked up one of their 4 channels. I'll see how much I like it
Also which one?? They have 3 it seems...
How the... Lol
