Showing how it failed repeatedly, isn't really a testament of greatness. More like showing a weak spot.
That's just the way I'm reading it anyway.
Well by making this thread, as stated before, I wanted to show both. A) how much abuse it is capable of enduring B) showing that this is a very common weak point with this design and should be addressed to prevent further failures of the like
  • Replies 62
  • Views 9k
  • stevemead08
    stevemead08
    There are two truths here. 1st being. Nobody knows exactly what caused this. 2nd being. No manufacture makes 100% bullet proof equipment. Things like this happen to many end users and with equipment f
  • You boys are tough on equipment, LOL Man as much as you demo and beat on that sub it doesnt suprise me much. Playing a entire song at full tilt with alot of power is hell on anything, especially after
  • Lmao!!! I wish I was able to be less responsible with my money. Smh! Make sure to pm me the photos
Is there any other way of doing the leads? Seems like on a lot of different subs there is this same problem.
Conducting conversations with others, we have confirmed that the weakest point is from the Tinsel Lead to the Coil Lead. That is where the driver will fail first, every time. Again, this is confirmed with said owners of said type drivers.
I will once again throw it out there that it is one hell of a bad weak point when mounted non inverse and inside of an enclosure with any kind of screws.
In the event you do not have a screw driver/drill it could be too late and your car could be engulfed in flames if they are really getting that hot. Especially for some idiot doing phone book tricks just adding ignition to the already molten hot leads.. lol I love you Senchez!!
  • 2 weeks later...
I guess the Fi recognized the issue.
Whoa, is that from LV or is that a recone?
Las Vegas = fi lol
Fi posted it on fb
i would love to see the recones like this
Just taking a guess, but wouldn't that change the weight of the entire way the thing moves? It looks worse than putting those weights around rims of tires on a car in this case since it's attached directly to the center, but I understand looks can be deceiving which is why I ask.
  • 1 month later...
Yeah I'm having this same issue Senchez with my XSv2 15s and am planning on doing the 8 ga. direct leads to the failed one soon and possibly obtaining ZV4 surrounds. When this happened to me the surround ripped 1/2 way around the good woofer (and started the stressing the damaged woofers surround.
Yeah, the FOAD leads look awesome! haha. I wouldn't use those surrounds though, VERY different geometry lol. I had no issues outside of the lead. Hell, it still does a 144 with one coil lol.
Those look beefy as hell! When recone my SP4s hopefully these will be standard. :D
