January 29, 201412 yr Author Above pricing will go into effect 2/15/14. Current price is $345 SHIPPED Edited January 29, 201412 yr by Quentin Jarrell
January 29, 201411 yr Author Regarding the 1800watts/box rating. What frequency and what type of hpf?The formula used to calculate this rating uses the FS of the system as it's the point of greatest xmax. High pass filter is not a concern as cone movement is reduced with higher frequencies.
January 30, 201411 yr Regarding the 1800watts/box rating. What frequency and what type of hpf?The formula used to calculate this rating uses the FS of the system as it's the point of greatest xmax. High pass filter is not a concern as cone movement is reduced with higher frequencies. Your referring to a Low pass filter. I am talking about a "subsonic" filter.
January 30, 201411 yr Author How would 2 of the 12s do with an 8 inch round port? Tuned in the low 30s.ideally you would want a 9.7 inch diameter port for two 12s tuned to 30 hz. However you may not "hear" any port noise. If you have the space build a port with 75 square inches of surface area.
April 27, 201411 yr What is the RMS for the 12s?1800rms in given box to reach xmax.After playing with one. I'd out an 3k to it all day. Edited April 27, 201411 yr by Sencheezy
