Posted March 12, 201412 yr Is it important to have a battery isolator when installing a second battery?
March 12, 201412 yr Depends if you plan on playing with your car off or no, so yes it would be important to have if you play your system with the car off.
March 12, 201412 yr I would use one one a boat. I never listen to loud music in a car without it running because of voltage drop.
March 12, 201412 yr Author Thank you for the read...so i take it an Isolator will not be necessary, where in the configuration with two battery's would be the best place for my 175 farad and 1 farad caps? in between or after both batteries?
March 12, 201412 yr Author ^Never mind on that last question, I'll put the caps between the last battery and amp.
