I would be all over this...if it was 15!
It can fit in a 15 box, just cutout 18 size hole.
Go for it Bassink!
I don't have the height for an 18 and don't wanna fire it up
  • Replies 85
  • Views 8.7k
  • Quentin Jarrell
    Quentin Jarrell
    Wait till you see the production model this fall.     It contains a few components and tech never used in a transducer.
  • jcarter1885
    jcarter1885
    Seems this has turned into a chat log.
  • Like I say man, it WANTS a smaller box! haha   just grab a 15" box with an 18" hole. May need a little bit more port, but it'll be fine.
Yea I saw it in person at sbn. Sencheezy I was the guy that asked you how it sounded while you were next to Scott bowman s truck lol. That sub is a monster!
Wow I didn't know this existed...
good luck with sale,  im counting the days till fall
same here!
:bump:
Wow, this isn't sold yet? lol
I'm sooo tempted. I'm considering a xcon 18 as it is. I'd hate to be the noob that swipes this away from a more experienced/deserving member though.
If you want it, it's yours.
the way I see it,first come first served
If I had the cash I-40E would be on fire right about now!!!lol
Anyway for you to pull specs on if?
something like this
Qts: 50
Vas: 190.0
Fs: 24
Re: .95
Xmax: 37.5
Qms: 12.65
Qes: .52
SPL: 91.50
Pe: 3000
BL: 15.26
Dia: .406
Sd: .119
And I'm pretty sure the xmax is measured at 70% bl.
No 70% is ~45mm
The production model will use a 10 x 3 spider to reach full Xmax.
No 70% is ~45mm
Nevermind :P
No 70% is ~45mm
Goddamn
No 70% is ~45mm
Goddamn
bottom of coil to the next plate is 37.5MM then another 7.5MM until its only 70 percent saturated.  This of course doesn't account for stray flux which only adds to the xmax.  This is why Sanchez was able to play it on little power.  The coil stays nearly saturated for nearly the whole usable stroke of the suspension.
:bump:
:bump:
WTF I expected it to go FAST
I know :(
I could really use the money right now as well.
bump
