May 11, 201411 yr You send it to crescendo. Just send them an email. Depending on repair, it's about 100-200$
May 11, 201411 yr Author I already said wat happen in another tread So to day I was running another wire for my volt meter and when I was tightin down the wire to the remote input the ally key slipped out an tap the + and - terminals I have dual 1/0 inputs for less than a second... Is it fix able or do I have to take a loss and buy another one... It will not cut on fuses are good
May 12, 201411 yr I already said wat happen in another tread So to day I was running another wire for my volt meter and when I was tightin down the wire to the remote input the ally key slipped out an tap the + and - terminals I have dual 1/0 inputs for less than a second... Is it fix able or do I have to take a loss and buy another one... It will not cut on fuses are goodIv seen that happen to a few people. . Usually was around 100 or so to fix
May 12, 201411 yr Author The power was killed unhooked from the battery buts it's ok thanks. I'll email crescendo tomorrow and ship it off...any body no how long it would take for them to fix it and ship it back to me
May 12, 201411 yr Probably better off bypassing Crescendo altogether and just sending it to DB-R. Might be quicker since its no a warranty thing
May 12, 201411 yr Author Probably better off bypassing Crescendo altogether and just sending it to DB-R. Might be quicker since its no a warranty thingIs that the website....I will look into it
May 12, 201411 yr It all could of been avoiding if you didnt have those 2/0 inputs, pretty pointless on a 2k amp.
May 12, 201411 yr The power was killed unhooked from the battery buts it's ok thanks. I'll email crescendo tomorrow and ship it off...any body no how long it would take for them to fix it and ship it back to meif the power disconnected what is the issue with crossing them. Jump a wire from the positive to remote
May 12, 201411 yr Probably better off bypassing Crescendo altogether and just sending it to DB-R. Might be quicker since its no a warranty thingIs that the website....I will look into it http://www.db-r.com/
May 12, 201411 yr The power was killed unhooked from the battery buts it's ok thanks. I'll email crescendo tomorrow and ship it off...any body no how long it would take for them to fix it and ship it back to meHow did anything happen if there was no power?
May 12, 201411 yr The power was killed unhooked from the battery buts it's ok thanks. I'll email crescendo tomorrow and ship it off...any body no how long it would take for them to fix it and ship it back to meHow did anything happen if there was no power?my point exactly
May 13, 201411 yr God that sucks... Ive only lost ONE amp.... was a month ago. Sucks.. (dc 175.4, one day worked, next didnt)
May 13, 201411 yr Author there will still be a small amount of power stored inside the amp.Wat this guy said thanks for seeing it another way...thanks well can't wait to see if db-r can fix it
