  • Admin
  • Replies 99
  • Views 19.3k
Hey, be careful with this recone ok. It has already been broughton attention to Mark from Zack when we were all at world finals. Basically, the spiders seem to be shorter. As you can see. So when under high excusurion, the leads and touch the basket which could cause a short. just an heads up.
Gonna heat shrink them when I solder the leads.
great idea
The box is going to be 15.5ft^3 tuned to 30hz for the rear chamber, and 24.5ft^3 tuned to 50hz for the front chamber. The entire box is double layered with the sub baffle quadruple layered and front of box triple layered. The overall dimensions are 37.75" wide x 35" tall x 72.25" deep. Everything but the front is going to be sandwiched between the top and bottom pieces, so naturally everything between them will be 32" tall.
Instead of buying a new alt for the dual alt setup I'll be using the old alt out of the mustang, going to convert it to self exciting and fabricate a bracket, whenever I get the money I'll replace the factory alt with a new mechman.
I need to figure out how I'm going to cut .25" steel, lol.
Plasma cutter would be nice !
dude, I Phucking love your wall design!
Yeah same here
A variable speed jigsaw with a 24 to 18 teeth per inch blade and some ATF for cutting oil will get the job done through 1/4" steel. Looks good.
  • 2 weeks later...
  • 1 month later...
Here's something I've been working on after work for a little something. It's my old mechman 320 from the mustang. I finally finished it up for the most part. Just need to drill some mounting holes and call it a day.
Shit just got real, makes the enclosure i built yesterday look pathetic.
What color are you gonna paint the inside
can't wait to see this playing!
  • Admin
Nice update Julian.
  • 3 weeks later...
Any updates
  • 2 weeks later...
knock knock
Who there
