They are here early -- original ETA was October.
* Current MAP is $299
* RMS is still rated at 600-watts
* The coil is the same as the 10/12/15" models
* The motor is 10mm wider, 10mm taller, and the top plate is 20% thicker than the 10/12/15" models -- in order to drive the heavier moving mass
* The spider is an 8 3/8" with standard XL leads (10/12/15 are 7" spider and recently also got XL leads)
* It features a newly custom tooled high roll foam surround
10329725_675075952547879_185459901818231
10511510_685631291492345_521332052505730
10483915_675075775881230_760829897397296
* DUAL-2 SPECS
10556928_675075739214567_291707396639895
* DUAL-4 SPECS
:phatyo:
