October 1, 201410 yr Nope, not worth it even if you planned on using it the rest of your life.Not worth it even if your going to use it once.
October 1, 201410 yr This forum doesn't approve of the DD1. Go to any other forums and you'll hear some that love it and some that suggest to use that or an oscope. I have a DD1 and It works great, the only downside is it only "approves" one frequency (40hz). I used it to set my gain and then fine tuned it while playing some music I frequently listen to. Probably going to get a lot of hate for it, but oh well.
October 1, 201410 yr Just to give a little incite as to what I feel why most people don't like these things. You set your gain at a single frequency as previously mentioned. Music does not play one frequency and with that being said is dynamic in such a way that different frequencies will have different power requirements from your system as a whole. Your song may dip to below 30 hz and clip like crazy because each amp is different in their dynamic capability. On the other hand it seems people are also confused on whether to set everything with the car on/off, what volume the head unit is at, or even where the subwoofer level is. It is much better to familiarize yourself with your entire system in such a fashion you can hear things by ear so you can get a sense what sounds right/wrong.
October 1, 201410 yr This forum doesn't approve of the DD1. Go to any other forums and you'll hear some that love it and some that suggest to use that or an oscope. I have a DD1 and It works great, the only downside is it only "approves" one frequency (40hz).I used it to set my gain and then fine tuned it while playing some music I frequently listen to.Probably going to get a lot of hate for it, but oh well.It used to be a widely held belief that the world was flat. If a guy walked in to a pub and asked a table of men who happened to be "rounders" if the world was flat, they'd say no it's round. But an individual sitting across the isle from them hears this and leans over to the guy and says "yeah, the guys at that table are just nuts. Walk up to any other table and they'll tell you it's flat ! "The world isn't flat, no matter how many other tables say that it is.
October 1, 201410 yr This forum doesn't approve of the DD1. Go to any other forums and you'll hear some that love it and some that suggest to use that or an oscope. I have a DD1 and It works great, the only downside is it only "approves" one frequency (40hz).I used it to set my gain and then fine tuned it while playing some music I frequently listen to.Probably going to get a lot of hate for it, but oh well.It used to be a widely held belief that the world was flat. If a guy walked in to a pub and asked a table of men who happened to be "rounders" if the world was flat, they'd say no it's round. But an individual sitting across the isle from them hears this and leans over to the guy and says "yeah, the guys at that table are just nuts. Walk up to any other table and they'll tell you it's flat ! "The world isn't flat, no matter how many other tables say that it is. Like I said I used it as a starting point see how everything sounds. Like I set it with a 0db tone and it was quiet so I manually turned the gain up, and now its sounds much better, no clipping or smell that I can detect. I have a PAC-LC1 so I can adjust the levels for each song as like we've both said every song and freq is different some may clip while others could go way louder.
October 2, 201410 yr Popular Post This forum doesn't approve of the DD1. Go to any other forums and you'll hear some that love it and some that suggest to use that or an oscope. I have a DD1 and It works great, the only downside is it only "approves" one frequency (40hz). I used it to set my gain and then fine tuned it while playing some music I frequently listen to. Probably going to get a lot of hate for it, but oh well.The point is, its just as easy to tune the gain to the music you frequently listen to in the first place. Therefore useless.
October 2, 201410 yr Popular Post Like I said I used it as a starting point see how everything sounds. Like I set it with a 0db tone and it was quiet so I manually turned the gain up, and now its sounds much better, no clipping or smell that I can detect. I have a PAC-LC1 so I can adjust the levels for each song as like we've both said every song and freq is different some may clip while others could go way louder.LMAO...then the DD1 did absolutely NOTHING to for you. The fact you used it as a "starting point" with a 0db test tone then manually increased the gain means you negated any affect the DD1 had on the setting. You didn't set your gain with the assistance of the DD1, you set your gain by ear...exactly the same as we suggested here.
October 2, 201410 yr This forum doesn't approve of the DD1. Go to any other forums and you'll hear some that love it and some that suggest to use that or an oscope. I have a DD1 and It works great, the only downside is it only "approves" one frequency (40hz).I used it to set my gain and then fine tuned it while playing some music I frequently listen to.Probably going to get a lot of hate for it, but oh well.It used to be a widely held belief that the world was flat. If a guy walked in to a pub and asked a table of men who happened to be "rounders" if the world was flat, they'd say no it's round. But an individual sitting across the isle from them hears this and leans over to the guy and says "yeah, the guys at that table are just nuts. Walk up to any other table and they'll tell you it's flat ! "The world isn't flat, no matter how many other tables say that it is. Like I said I used it as a starting point see how everything sounds. Like I set it with a 0db tone and it was quiet so I manually turned the gain up, and now its sounds much better, no clipping or smell that I can detect. I have a PAC-LC1 so I can adjust the levels for each song as like we've both said every song and freq is different some may clip while others could go way louder. Why not save over 100$ (don't know the exact price), and just start out at minimum gain?
October 2, 201410 yr Popular Post And this is exactly what EVERYONE who recommends using it is like. Absolutely no idea what they are doing, using a tool that does nothing for nothing and the worst part is since they spent money on it they feel like they got some value. While Steve is a complete douche for offering something up for sale that has no value, I understand his desire to profit from the uninformed. I guess a fool and his money are easily parted and if he doesn't take advantage someone else will. Still SUPER shitty to offer up a piece of trash for good money and then create crap propaganda to convince nooblets to buy it.
October 2, 201410 yr I could probably do with out it, but for some people I know it works because it tends to set your gains lower then clipping so for someone who doesn't know what they're doing (old me) it works fine as they set it where it is and leave it, sure they might not be getting 100% but they won't be clipping. On another note $150 is a complete rip off, I paid that but oh well. $50 would be a better price.
October 2, 201410 yr I could probably do with out it, but for some people I know it works because it tends to set your gains lower then clipping so for someone who doesn't know what they're doing (old me) it works fine as they set it where it is and leave it, sure they might not be getting 100% but they won't be clipping. On another note $150 is a complete rip off, I paid that but oh well. $50 would be a better price.You could do the same thing with your ears for free. https://www.youtube.com/watch?v=57RUYL6lsq0 Edited October 2, 201410 yr by pmureika
October 2, 201410 yr I could probably do with out it, but for some people I know it works because it tends to set your gains lower then clipping so for someone who doesn't know what they're doing (old me) it works fine as they set it where it is and leave it, sure they might not be getting 100% but they won't be clipping.On another note $150 is a complete rip off, I paid that but oh well. $50 would be a better price.For someone who doesn't know what they're doing, it's also a good way to break things as it's uselessness goes both ways.
October 2, 201410 yr I could probably do with out it, but for some people I know it works because it tends to set your gains lower then clipping so for someone who doesn't know what they're doing (old me) it works fine as they set it where it is and leave it, sure they might not be getting 100% but they won't be clipping.On another note $150 is a complete rip off, I paid that but oh well. $50 would be a better price.For someone who doesn't know what they're doing, it's also a good way to break things as it's uselessness goes both ways. Its only good as a paper weight.
October 2, 201410 yr Besides. EVERYONE is running their transducers at least to 10 percent distortion and WELL over 40 percent in the sub stage. Why would they give a peanut butter jelly sand which if their amp is set to <1%?
October 2, 201410 yr I could probably do with out it, but for some people I know it works because it tends to set your gains lower then clipping so for someone who doesn't know what they're doing (old me) it works fine as they set it where it is and leave it, sure they might not be getting 100% but they won't be clipping. On another note $150 is a complete rip off, I paid that but oh well. $50 would be a better price.You didn't even use it and if you did your system is setup like utter fucking shit. If someone GAVE you $100 for taking a DD-1 then it'd be a good deal. Paying even $0.01 is WAY too much as it has NO value. I could probably do with out it, but for some people I know it works because it tends to set your gains lower then clipping so for someone who doesn't know what they're doing (old me) it works fine as they set it where it is and leave it, sure they might not be getting 100% but they won't be clipping. On another note $150 is a complete rip off, I paid that but oh well. $50 would be a better price.You could do the same thing with your ears for free. https://www.youtube.com/watch?v=57RUYL6lsq0[/quoteAmusingly when Steve the dumbass himself came on here and tried to discuss it's value (ie show his ignorance) he flat out said it was pointless for competition and then ended up agreeing with all the points that stated the device was pointless for daily or any stereo as well. He ran away at that point.There is NO technical merit for using it for anything. If you truly believe there is feel free to simply state that technical merit and we will show you the flaw in your logic.
October 2, 201410 yr Ok, I can't argue the value of a paperweight so don't try that one.Well it is made of plastic. Probably kinda light.
October 2, 201410 yr Ok, I can't argue the value of a paperweight so don't try that one.Well it is made of plastic. Probably kinda light. Perhaps a wrestling prop where someone can slam it down and watch it shatter in a thousand pieces would be most useful. I bet we could measure the sound of it slapping the floor at 40hz then
October 3, 201410 yr Ok, I can't argue the value of a paperweight so don't try that one. Well it is made of plastic. Probably kinda light.Never implied it was good for that, just can't argue that value. I don't use paperweights. Ok, I can't argue the value of a paperweight so don't try that one. Well it is made of plastic. Probably kinda light. Perhaps a wrestling prop where someone can slam it down and watch it shatter in a thousand pieces would be most useful. I bet we could measure the sound of it slapping the floor at 40hz then I have many other things that I'd rather measure with my Acoustic Camera...however, if someone donates one for the smash perhaps you could convince me differently.
