Posted October 8, 201412 yr I have a mechman 240a alternator with a xs power d5100 upfront everything wired up and running smooth. Now when installing my rear battery (another d5100) should I run both power and ground wires to the back battery or just the charge wire and ground in the trunk? Thank you in advance.
October 8, 201412 yr I would do a - and + run from front to rear batts.I have rear batts grounded in the rear also Edited October 8, 201412 yr by frogcase2002
October 8, 201412 yr Author Ok I have it that way now and now I get a pop/thump through my sub with no input signal so I'm pretty sure it's in the grounding not deck or rca related.
October 8, 201412 yr Author That was my next question should I also ground that rear battery in the trunk too?
October 8, 201412 yr That was my next question should I also ground that rear battery in the trunk too? Frame is the preferred method, but if you cannot get to the frame try to find an area and clear it of any dust and debris and proceed to sand it down before using it. Try and use fasteners of the appropriate size that fit in the lug opening or use a ground block that mounts to the surface with hardware. I find ground to be just as important as the power wire itself to be able to complete a circuit and shouldn't be thrown on just any old seat bolt or trunk latch bolt without assessing to make sure the area is capable first.
October 8, 201412 yr Author It's a uni - body car so no beefy frame to go to. But all my grounds are on bare metal and tight. Everything was good until I installed the rear battery. I'm running active with a deh 80prs. I have the tweeter amp on the front battery and the mid and sub amp on the rear battery. The mid and sub amps are both on the same exact ground and same exact power and my mid amp is quite no noise on turn off but the sub amp thumps. Before with the one battery up front everything was good no noise no thump on turn off. But ever since installing the second battery in the rear along with new amp and sub I have this thump on turn off. I did notice when i ungrounded the tweeter amp it took way longer for the sub to thump Edited October 8, 201412 yr by 1way
October 8, 201412 yr How do you have the positive from front to rear and yes I would ground the rear battery with as short of wire as possible. I don't like to go more then 2 feet.Also could be the amp? Any pics you could upload? Edited October 8, 201412 yr by pmureika
October 8, 201412 yr My crescendo bc2000s did the thump noise when cutting off but my kicker zx1500 did not so it might be the amp...but i dont know what im talking about half the time
October 8, 201412 yr Some amps have a soft turn on thump and some dont. If the same amps were in before doing upgrades and changes and its one of thise thats thumping, then check all your grounds. Might not have a good ground on your rear battery.My crescendo bc2000s did the thump noise when cutting off but my kicker zx1500 did not so it might be the amp...but i dont know what im talking about half the timeCool story bro Edited October 8, 201412 yr by jay-cee
October 8, 201412 yr Author I have the positive for the rear battery right off the charge post of the alternator then goes right through the firewall to the rear
October 8, 201412 yr I have the positive for the rear battery right off the charge post of the alternator then goes right through the firewall to the rearDo you have the big three done?
October 8, 201412 yr Author I have a digital design m2b running my sub a Fi BL 15 and I have a digital design s2b for mids. I hooked up the sub to the s2b to see if it was the m2b but the thump got louder. My other sub setup was a kicker 12 L7 and a jl e1800d and never had a problem. Now with the digital design amps I have problems.
October 8, 201412 yr Author I have the positive for the rear battery right off the charge post of the alternator then goes right through the firewall to the rearDo you have the big three done?Yes I have the big three done with all ofc 1/0 and a ground from alt casing to battery recommended by mechman for there alternators.
October 8, 201412 yr Author Some amps have a soft turn on thump and some dont. If the same amps were in before doing upgrades and changes and its one of thise thats thumping, then check all your grounds. Might not have a good ground on your rear battery.My crescendo bc2000s did the thump noise when cutting off but my kicker zx1500 did not so it might be the amp...but i dont know what im talking about half the timeCool story broI think it's ground related to... I just spent all day going over all grounds went over all connections everything is tight and down to bare metal. I have been putting systems in my cars for 14 years now and never once had any noise issue's. But I guess there's a first for everything.
