Posted October 24, 201412 yr Will a icon sound good on 400 wrms? The box size is 1.45 cubic ft @ 40 hz Edited October 24, 201412 yr by pmureika
October 24, 201412 yr 10"? 40hz is kind of high for my taste, but my ICON 12 sounds very nice on 600rms in 2.25ft^3 @ 33ish.edit: better than anything else I've run in this power/enclosure range. Edited October 24, 201412 yr by bombsaway
October 24, 201412 yr I don't know because I don't know what sounds good to you. You running a stock front stage?
October 24, 201412 yr Author I have a exiting system that has 400 rms going to it. I want to know if a icon would work as a upgrade? Current sub is a SQ hds-210.
October 24, 201412 yr Is the SQ sub in the 1.45 ft^3 box tuned to 40 hz? If so, I would say make a new box tuned lower (like 35hz, maybe 32) and if that isn't what you like then I would suggest more surface area.
October 25, 201412 yr the Icon is more of an SQ sub.....personally I would not tune it any higher than 33hz I have had a 12" Icon on 500w rms in a buddies truck and it moved good...took a while to break in but IMO the Icon is one of the nicest sounding subs on the market
October 25, 201412 yr Author I don,t want to build a new box because of my budget. This would be a used icon 10 going in the box.That is what I am looking for is more sq. Edited October 25, 201412 yr by pmureika
October 25, 201412 yr Author I don't know because I don't know what sounds good to you. You running a stock front stage?Yes a JVC head unit with a Barbara Ann amp running the comps in the doors and channels 3 & 4 running the sub.
October 25, 201412 yr I'm running my two Icon 12's on 350w rms for the pair....still has decent output and sounds very good IMHO. Tuned @ 30hz
October 25, 201412 yr Author I'm running my two Icon 12's on 350w rms for the pair....still has decent output and sounds very good IMHO. Tuned @ 30hzThe box I have right now is tuned to 40hz and I don't have money to make a new one.
October 25, 201412 yr What kind of music do you listen to? Most sq builds have a sub stage tuned very low usually. I think you will see a little improvement from just a direct swap in drivers but I think if you made a new box, it would be cheaper with better results.
October 25, 201412 yr Author What kind of music do you listen to? Most sq builds have a sub stage tuned very low usually. I think you will see a little improvement from just a direct swap in drivers but I think if you made a new box, it would be cheaper with better results.Mostly classic rock.
October 25, 201412 yr You would be wasting money buying a used ICON only to throw it in the same box. If you want to sound better you need a better enclosure.
October 26, 201412 yr I'm running my two Icon 12's on 350w rms for the pair....still has decent output and sounds very good IMHO. Tuned @ 30hzThe box I have right now is tuned to 40hz and I don't have money to make a new one. What we are saying is that it will perform very well on low power Edited October 26, 201412 yr by garychurch84
October 26, 201412 yr You been on this forum long enough to know their is no such thing as underpowering a subwoofer and stuffing a subwoofer in a pre-fab box even if its a custom box for another sub is a no go. Every thread you make is ridiculous and you give the least bit of information, like you tell the newcomers when they start a thread please read the rules before making a topic. You need to follow that same advice that you dish out.If thats all you can get at the moment and you wanna go for it then do it as it is your money and install. If you want optimal results then stick witt the recommended info on SSA's site for the Icon enclosures. Yes it will work, how good it will work is subjective so as long as you like it.http://www.soundsolutionsaudio.com/forum/topic/13994-attention-noobs/ Edited October 26, 201412 yr by jay-cee
October 26, 201412 yr Author Plug the port and run it sealed.That is a option, but I like to run ported boxes in my Jeep Liberty. I might have to skip new tractor tires and build a better box.
October 26, 201412 yr Plug the port and run it sealed.That is a option, but I like to run ported boxes in my Jeep Liberty. I might have to skip new tractor tires and build a better box.Build it on the large side to compensate for the power you are using, I loved my 15" Icon ported.
October 26, 201412 yr Author Plug the port and run it sealed.That is a option, but I like to run ported boxes in my Jeep Liberty. I might have to skip new tractor tires and build a better box.Build it on the large side to compensate for the power you are using, I loved my 15" Icon ported. That's what I was going to do if I build a new one. I took the sub out of the existing box and looked at it better. I am surprised that what I thought was a custom built box is a prefrab stuffed with poly fill. I will never have him build a box again. Or should I say claim to build a custom box. It sounded ok with the sq sub, but a icon won't like you said. Edited October 26, 201412 yr by pmureika
November 4, 201412 yr Admin To address just the power question, the Icon will perform on that power. Now I am not a fan of 40hz tuning for the Icon.
November 5, 201412 yr To address just the power question, the Icon will perform on that power. Now I am not a fan of 40hz tuning for the Icon.agreed
November 5, 201412 yr Author To address just the power question, the Icon will perform on that power. Now I am not a fan of 40hz tuning for the Icon.agreed New box coming 2.0 ft^3 @ 32hz. Do you think this will help? Edited November 5, 201412 yr by pmureika
