Posted May 29, 201511 yr I can't get the dustcap to stay in place,what am I doing wrong? Rubberized glue didn't hold,CA didn't hold,5 min epoxy didn't hold.i ruffed the surface of dustcap w/emery cloth. Time to step back and punt!Also the first two weeks after the recone I had to keep volume down my amp would protect on me. Now I can full tilt w/no issues,confused on that also. Edited May 29, 201511 yr by garychurch84
May 29, 201511 yr My nephew used five minute epoxy on this custom cap and it worked. Edited May 29, 201511 yr by pmureika
May 29, 201511 yr Author My nephew used five minute epoxy on this custom cap and it worked. the epoxy didn't set well on one side of cap for some reason
May 29, 201511 yr My nephew used five minute epoxy on this custom cap and it worked. the epoxy didn't set well on one side of cap for some reason You mean it didn't harden?
May 29, 201511 yr You used the spray with the ca glue? That stuff is usually crazy strong. . Where did you get the glue
May 29, 201511 yr Author My nephew used five minute epoxy on this custom cap and it worked. the epoxy didn't set well on one side of cap for some reasonYou mean it didn't harden?not completely
May 29, 201511 yr Author You used the spray with the ca glue? That stuff is usually crazy strong. . Where did you get the glueyes...ordered the kit from fixmyspeaker.comCame w/activator,rubberized,CA glue
May 29, 201511 yr You used the spray with the ca glue? That stuff is usually crazy strong. . Where did you get the glueyes...ordered the kit from fixmyspeaker.comCame w/activator,rubberized,CA glueI did a recone for someone a while ago and he ordered from there and I had problems with the glue. . Never had a problem with glue from ssa
May 29, 201511 yr Author You used the spray with the ca glue? That stuff is usually crazy strong. . Where did you get the glueyes...ordered the kit from fixmyspeaker.comCame w/activator,rubberized,CA glueI did a recone for someone a while ago and he ordered from there and I had problems with the glue. . Never had a problem with glue from ssaYou used the spray with the ca glue? That stuff is usually crazy strong. . Where did you get the glueyes...ordered the kit from fixmyspeaker.comCame w/activator,rubberized,CA glueI did a recone for someone a while ago and he ordered from there and I had problems with the glue. . Never had a problem with glue from ssathe ca got hard as a rock,it pulled the top layer of the cone loose
May 30, 201511 yr Also the first two weeks after the recone I had to keep volume down my amp would protect on me. Now I can full tilt w/no issues,confused on that also. The T/S parameters change (sometimes a lot) after the soft parts fully break in. This will change the the impedance curve and thus your load presented to the amplifier will be different.
May 30, 201511 yr My nephew used five minute epoxy on this custom cap and it worked. the epoxy didn't set well on one side of cap for some reasonYou mean it didn't harden?not completely It didn't get mixed well is all I can think of.
May 30, 201511 yr Author Also the first two weeks after the recone I had to keep volume down my amp would protect on me. Now I can full tilt w/no issues,confused on that also. The T/S parameters change (sometimes a lot) after the soft parts fully break in. This will change the the impedance curve and thus your load presented to the amplifier will be different.makes sence to me....thanks for the input
May 30, 201511 yr I had an issue with the top layer coming of my zcon cones. I they looked like shit by the time i got them to stick.
May 30, 201511 yr Author I had an issue with the top layer coming of my zcon cones. I they looked like shit by the time i got them to stick.this is a zcon as well... Definitely looks like shit lol
May 30, 201511 yr I had an issue with the top layer coming of my zcon cones.I they looked like shit by the time i got them to stick.this is a zcon as well... Definitely looks like shit lol It cant be that bad it's a Z-CON!!...I bet have seen way worse!!!!
June 1, 201511 yr when putting on a dust cap wear latex gloves.........all you have to do is touch the sanded surface of the dust cap with oily/sweaty skin and it will come loose before gluing wipe the cone surface with 99% Isopropyl as well as the dustcap before it is sanded...they will never come loose I also make a handle out of masking tape and stick it to the center of the dustcap so I havesomething to hold on to when I drop it into place
June 1, 201511 yr when putting on a dust cap wear latex gloves.........all you have to do is touch the sanded surface of the dust cap with oily/sweaty skin and it will come loosebefore gluing wipe the cone surface with 99% Isopropyl as well as the dustcap before it is sanded...they will never come looseI also make a handle out of masking tape and stick it to the center of the dustcap so I havesomething to hold on to when I drop it into placePro tip... Nice. Will remember that for sure
June 2, 201511 yr Author when putting on a dust cap wear latex gloves.........all you have to do is touch the sanded surface of the dust cap with oily/sweaty skin and it will come loosebefore gluing wipe the cone surface with 99% Isopropyl as well as the dustcap before it is sanded...they will never come looseI also make a handle out of masking tape and stick it to the center of the dustcap so I havesomething to hold on to when I drop it into placePro tip... Nice. Will remember that for surewhen putting on a dust cap wear latex gloves.........all you have to do is touch the sanded surface of the dust cap with oily/sweaty skin and it will come loose before gluing wipe the cone surface with 99% Isopropyl as well as the dustcap before it is sanded...they will never come loose I also make a handle out of masking tape and stick it to the center of the dustcap so I havesomething to hold on to when I drop it into placedone all this...minus the gloves
June 18, 201511 yr Author Its finally on!!!Used a different name brand 5 min epoxyPermatex 5min epoxy sucks d!!!Loctite 5 min epoxy ftw!!!
