Posted September 19, 201511 yr I have 10-8 inch and 6-10 inch PRV audio speakers. I have Taramps HD8000 2ohm running all 16 speakers. My question is will I get better performance from all 16 speakers if I separate the 8's and 10's to different amps?It does get reasonable but in my opinion I have heard smaller systems get louder with less power.
September 19, 201511 yr It'd be best if you ran all the same size speaker...or at least chose reasonable sizes to run different frequency ranges. That being said the worst thing you could do is run two different drivers to the same channel of an amplifier without designing an in situ passive crossover to make it work.
September 19, 201511 yr Isn't that HD8000 a mono subwoofer amp? You don't even have stereo channel (Left/Right) separation. It can't begin to sound right let alone work as expected.
September 20, 201511 yr Isn't that HD8000 a mono subwoofer amp? You don't even have stereo channel (Left/Right) separation. It can't begin to sound right let alone work as expected.rYou are right Alton. http://techzoneus.com/product/hd-8000
September 20, 201511 yr I would start over or take a step or two back. You probably have cancellation among other things. More is not always better. But if you are only worried about making noise and being loud then you are on the right path.Like stated before you need another amp, I would never run my mids on a mono amp. More information about your build would help as well as pictures. Edited September 20, 201511 yr by jay-cee
September 20, 201511 yr I read some where he has something like 10 super tweeters in that set up.Not sure what amplifier power he has on it.
September 22, 201511 yr Is this a show vehicle or a musical vehicle? Edited September 22, 201511 yr by SpeakerBoy
September 22, 201511 yr Is this a show vehicle or a musical vehicle?With the equipment he has just for the front stage should answer your question, more than likely a show or demo vehicle.
September 27, 201511 yr Is this a show vehicle or a musical vehicle?With the equipment he has just for the front stage should answer your question, more than likely a show or demo vehicle.Well yeah, but from the way he posts I wasn't sure o.O
