Posted March 9, 201610 yr Quick question. If I have two subs at 1 ohm each and they were wired into a mono amp with 4 connectors, would the impendance come to 1 ohms since they were technically in parallel?
March 9, 201610 yr Author The amp is mono, paralleled internally, it's the 2400 Incriminator sold from the ssa store.
March 9, 201610 yr if each sub is 1 ohm, and the amp parallels internally, then you would have a .5 ohm load. To get 1 ohm at the amp, you need 2 ohms on either side in this case.
March 10, 201610 yr 1 hour ago, nigel said: if each sub is 1 ohm, and the amp parallels internally, then you would have a .5 ohm load. To get 1 ohm at the amp, you need 2 ohms on either side in this case. Hes talking about dual 1 ohm Subs. . If each sub Is wired In Series then each sub will be wired at 2 at the amp In Parallel to make It 1 ohm
