March 5, 20178 yr On 2/14/2017 at 1:11 PM, ludeman said: Didn't realize how heavy the subs were until I had to lift them up to put them in the box!! Try lifting the sd team subs. Nearly got a hernia holding them in place to bolt up!
March 31, 20178 yr Author Update: Was getting low voltage readings, resting at 12.0 car running is 13.9 - 14.2! Pulled out batteries and my XS power's are done after 7 years of hard work, the D3400 was resting at 9.5, on the charger (4 times) it went in to desulfation mode for a few hours then read Bad Battery! The D3100 charges normal goes to 100% then drops to 70% over night! Now the resting voltage is 12.5, running is 14.5 - 14.3! Now I'm debating on which batteries to get. As for stock location there is no real impressive replacement, 1 might have a higher Ah but lacks in reserve or another category, but none is higher in all categories compared to factory agm. On to the battery bank, I like the Limitless Lithiums. Edited March 31, 20178 yr by ludeman
March 31, 20178 yr 24 minutes ago, ludeman said: Update: Was getting low voltage readings, resting at 12.0 car running is 13.9 - 14.2! Pulled out batteries and my XS power's are done after 7 years of hard work, the D3400 was resting at 9.5, on the charger (4 times) it went in to desulfation mode for a few hours then read Bad Battery! The D3100 charges normal goes to 100% then drops to 70% over night! Now the resting voltage is 12.5, running is 14.5 - 14.3! Now I'm debating on which batteries to get. Maybe it's time to try Lithium batteries. Personally, I'd love to. But shipping batteries oversea can only be done by boat. It's harder for me. I'm waiting for the SSA tweeters too. Nice build.
April 1, 20178 yr Now thats a good looking build. Really thinking of getting four of the evil 6.5s for my front doors. Still looking for front stage for my synergy 150.4.
April 3, 20178 yr Author My choices: 1. 1 XS Power SB1000 2. 1 Limitless 20ah Lithium and 1 NSB 94r 3. 1 XS Power SB500 and 1 NSB 94r Let me hear some feed back!!! I'm stuck on choices. The cheapest is #3 most expensive is #2! Edited April 3, 20178 yr by ludeman
April 8, 20178 yr Author Another option if I get the Limitless 40ah lithium it will fit in OEM battery location!
April 11, 20178 yr Admin 29 minutes ago, ludeman said: Your SSA STORE Order Confirmation (#1X553)! Sweet!!! Thank you. Will you be at TDH?
April 22, 20178 yr Author TDH show is a no go as of now! I got radio noise in the speakers, I can hear the fan from the radio and a thump when it turns off all while the volume is at 0. No engine noise or alternator whine? Pulled the radio out switched rca's ran it on top of the interior and the same noise is there, ordered a ground loop isolator last night. Gonna try grounding the radio rca inputs in a few. Grounding the rca made it worst! Edited April 22, 20178 yr by ludeman
April 22, 20178 yr How do you have radio gounded? Did you make any changes to system before noise was introduced? I usually ground my radio with a 10 or 12 gauge wire to some metal behind my dash.
April 22, 20178 yr Author The radio ground was checked first, grounded to metal. Only change was the Northstar agm's. No noise if I power the speakers off the radio. Only when I use any rca output.
April 27, 20178 yr Very nice! I want to get my wife a radio with Carplay too! Excellent job on that enclosure! wow. Edited April 27, 20178 yr by crackinhedz
May 5, 20178 yr Author Your order number is: (1X948) preorder for SSA Evil 1's! Edited May 5, 20178 yr by ludeman
May 9, 20178 yr did you order the lithium battery yet??? I been looking at braille On 5/5/2017 at 7:47 AM, ludeman said: Your order number is: (1X948) preorder for SSA Evil 1's!
May 9, 20178 yr 14 minutes ago, Shogen said: did you order the lithium battery yet??? I been looking at braille Why would you look at Braille?? You're supposed to feel it not look at it...... sorry, couldn't help myself, lol
May 9, 20178 yr bruh..no words... smh 2 minutes ago, altoncustomtech said: Why would you look at Braille?? You're supposed to feel it not look at it...... sorry, couldn't help myself, lol
May 9, 20178 yr Author 1 hour ago, Shogen said: did you order the lithium battery yet??? I been looking at braille Didn't order yet ended up getting NSB group 94r & 31! Still debating on lithium. Needed to raise up my resting voltage closer to lithium! Now resting at 13.1 car off lithium rest at 13.2-13.3! I've also been looking at: http://timsk2batteries.wixsite.com/timsk2batteries
