Patiently waiting for the Evil 1's and good weather.
  • Replies 92
  • Views 19.5k
  • Box #2 taking form, much like box 1 but 4.5 c/f tuned to 35hz with port on drivers side for 2 Zv.4 12's. Just going to be raw finish for BassRace testing.
  • All is wired didn't take pictures!  Box #1 3c/f tuned to 34hz with DC XLm1 15":
  • Tonight's work still needs to be wired up! Had to break out the ole' dremel to do a little trimming:
On 2/14/2017 at 1:11 PM, ludeman said:
Didn't realize how heavy the subs were until I had to lift them up to put them in the box!!
Try lifting the sd team subs. Nearly got a hernia holding them in place to bolt up!
  • 4 weeks later...
Update: Was getting low voltage readings, resting at 12.0 car running is 13.9 - 14.2! Pulled out batteries and my XS power's are done after 7 years of hard work, the D3400 was resting at 9.5, on the charger (4 times) it went in to desulfation mode for a few hours then read Bad Battery! The D3100 charges normal goes to 100% then drops to 70% over night! Now the resting voltage is 12.5, running is 14.5 - 14.3! Now I'm debating on which batteries to get. As for stock location there is no real impressive replacement, 1 might have a higher Ah but lacks in reserve or another category, but none is higher in all categories compared to factory agm.
On to the battery bank, I like the Limitless Lithiums.
Edited by ludeman
Maybe it's time to try Lithium batteries.
Personally, I'd love to. But shipping batteries oversea can only be done by boat. It's harder for me.
I'm waiting for the SSA tweeters too.
Nice build.
Might have room for SuperCaps gotta measure this!
  • Admin
Might be able to sneak an XP750 in there too.
Now thats a good looking build. Really thinking of getting four of the evil 6.5s for my front doors. Still looking for front stage for my synergy 150.4.
My choices:
1. 1 XS Power SB1000
2. 1 Limitless 20ah Lithium and 1 NSB 94r
3. 1 XS Power SB500 and 1 NSB 94r
Let me hear some feed back!!! I'm stuck on choices. The cheapest is #3 most expensive is #2!
Edited by ludeman
Another option if I get the Limitless 40ah lithium it will fit in OEM battery location!
Your SSA STORE Order Confirmation (#1X553)!
  • Admin
Sweet!!! Thank you.  Will you be at TDH?
I'll be there on Sunday
  • 2 weeks later...
TDH show is a no go as of now! I got radio noise in the speakers, I can hear the fan from the radio and a thump when it turns off all while the volume is at 0. No engine noise or alternator whine? Pulled the radio out switched rca's ran it on top of the interior and the same noise is there, ordered a ground loop isolator last night. Gonna try grounding the radio rca inputs in a few.
Grounding the rca made it worst!
Edited by ludeman
How do you have radio gounded? Did you make any changes to system before noise was introduced?
I usually ground my radio with a 10 or 12 gauge wire to some metal behind my dash.
The radio ground was checked first, grounded to metal. Only change was the Northstar agm's.
No noise if I power the speakers off the radio. Only when I use any rca output.
Bad Radio! Got a same model open box from Best Buy!
My daughter need to charge her iPhone, radio came alive: temporary_zpsxv4ioz5l.jpg
Very nice!
I want to get my wife a radio with Carplay too! Excellent job on that enclosure! wow.
Edited by crackinhedz
Your order number is: (1X948) preorder for SSA Evil 1's!
Edited by ludeman
did you order the lithium battery yet??? I been looking at braille
Why would you look at Braille??  You're supposed to feel it not look at it......
sorry, couldn't help myself, lol
bruh..no words... smh
Didn't order yet ended up getting NSB group 94r & 31! Still debating on lithium. Needed to raise up my resting voltage closer to lithium! Now resting at 13.1 car off lithium rest at 13.2-13.3! I've also been looking at: http://timsk2batteries.wixsite.com/timsk2batteries
  • Popular Post
What's in the box: temporary_zpsyuntvxrp.jpg
Edited by ludeman
