October 1, 20188 yr 10 hours ago, Tirefryr said: Gotta love an amp with a REAL heatsink! Exactly what I was thinking. Yum.
October 2, 20188 yr Author On 9/30/2018 at 10:34 PM, Tirefryr said: Gotta love an amp with a REAL heatsink! 13 hours ago, ///M5 said: Exactly what I was thinking. Yum. Thank you for posting guys !!! 23 hours ago, Mark LaFountain said: Looks good. Have you fired it up yet? So far just a few test tones with the Laptop. No music yet. Working on it Boss Man !!!
October 6, 20188 yr Author On 10/2/2018 at 8:58 PM, j-roadtatts said: Love the build Randall!! Clean and simple. thanks for posting! Thank you Sir. Yes, that’s the goal. Running wires for the front stage this weekend. Hoping to start tuning the A-Pilar drivers soon.
October 14, 20187 yr Author Popular Post Update: Got my 2 way passive set up in and the stage and image process has started !!! It's all stealthy so not much WOW factor, but I'm working on it. I will post pics asap. for now, I'm keeping things simple already had the equipment and got more if needed !!!
October 19, 20187 yr Juicy build..i was looking into linear power cause of you.but it's not something i can afford at the moment. Anyways that dash pad.did you buy for looks or to help with the soundstage
October 19, 20187 yr Author Thank you Sir. Yea, Linear Power is a bit pricey, but worth every penny when it comes to power and dynamics. As for the dash pad, other than looking great and protecting the dash from the sun, it definitely helps with the stage and image. wish I had more time to work on this truck.
November 1, 20187 yr Looking good Randal! Purple LP amps make me all tingly. Glad my build log helped. It was my first 'big' install.
November 4, 20187 yr Author On 11/1/2018 at 2:29 AM, Lee Carter said: Looking good Randal! Purple LP amps make me all tingly. Glad my build log helped. It was my first 'big' install. Thank you Sir !!!
November 4, 20187 yr Author Alright Bitches !!! Front Stage UPGRADES !!! Trying my best guys. Please remember, nothing is set in stone and I'm constantly testing and tuning. This will be a 2 way passive front stage 6.5" driver and tweet setup. One of the cool things I really like about this Avalanche is the tweeter placement. Not the angles of the tweet, but the actual location in reference to the mid bass driver location. According to the good ole measuring tape, it all measures out so that I can time align mid and tweet together. Thank God !!! This location is almost the same as the 2002 Ford F150 Supercrew I was working on. So for testing purposes, I took the stock tweeters out and apart and installed the pods out of the Ford and directly on to the BOSE grilles. Sorry for the night pics. I know guys, that's not on axis or off axis. Those tweets are on adjustable pedestals and THIS is where the Stage and image sounds best to me. No "tricking or notch EQ'ing" here. Left and Right separation seems to be Dead on Balls Accurate as is. I may change the angles a little more on axis, might help, we will see. But with this truck, they will stay in this area and not go onto the dash. After a couple of SQ comps, I think the A-pillars will be ready for Fiberglass. As for the doors. Nice baffle with a 6.5" driver for midbass. Deadning and MLV ??? As soon as I can afford it guys. Unfortunately, working on a very tight (closer to none at the moment) budget. What can I say, Shit Happens.
November 4, 20187 yr Sorry for the budget. Those are off axis btw. Anything not on, is off...and those are really off. Super funny when that works.
November 4, 20187 yr Author 2 hours ago, ///M5 said: Sorry for the budget. Those are off axis btw. Anything not on, is off...and those are really off. Super funny when that works. Yes, I got this. Me and my late posting. LOL, Sorry for the Mislead brother. Those pods are adjustable so tuning can start. Haven't had time. but sounds way better than stock !!! The driver tweeter looks great since I'm tuning for driver's seat, but the passenger tweet desperately needs turning towards the driver about 45 degrees. Since you have a similar ride, and If you don't mind me asking, what are you thinking about the front stages on these vehicles?? I want very stealthy, but don't see very much hiding for the tweeters and sound correctly. I am ALL open to suggestions !!!
November 4, 20187 yr Author There is a removable dash plate at the defrost vents. Gave thought about flush mounting a 4” driver and tweet, but there is absolutely no room under that panel. I love the fact of a near flat dash so I’m not wanting a dash pod for drivers. The Bose grilles will be removed for permanent mounting, but for now, helps keeping me from drilling holes all over my a-Pilar’s. Trying my best to keep things simple. You would know I’d catch hell with this. It’s all good. Gonna take time.
November 4, 20187 yr Not a huge fan of the dash on these. Nothing seemed to work perfect. Mine are equally off axis but in the opposite direction. My temp mounts wouldn't have let me steer them the way you have them pointed. What works, works. Do that I have a completely different set of processing than you do. I will add however that my time aligment is COMPLETELy different for all 4 drivers. Mine mids are mounted lower than yours though.
November 5, 20187 yr Author Guess if you’re running fully active you kinda have to time align separately. No way around it. Wish I could hear it !!! what’s strange to me is we should have very similar doors and panels. Not real sure what year model you have but thinking 07-13 should be similar. I may do some more measuring next chance I get. Appreciate your input Sean !!!
November 5, 20187 yr I have an Escalade. My speakers are in the bottom of the door...which relooking at your pictures yours are as well. Doh. I sit really high in the cab though as I am 6'7". I mistook the supercrew speaker location to memory and not the avy.
November 28, 20187 yr Author On 11/5/2018 at 3:37 PM, ///M5 said: I mistook the supercrew speaker location to memory and not the avy. LOL Gotcha. Working with a couple of mixed drinks, a measuring tape, a couple of test dummies, and some VERY well recorded music ... I have completely reset the angles of the tweeters. Both were raised up over the hump of the dash and repositioned more on Axis. Not necessarily directly to the driver, more like the driver's side tweeter to the passenger's ear and the passenger's tweeter to the driver's ear. Amazing difference !!! The stage and Image is VERY pronounce !!! Deep onto the hood and beyond the vehicle's side mirrors where everything should be !!! I had a question if raising the tweeters would create any separation between the tweets and door mid drivers, but I have not heard anything anywhere close to separation. Thank God this is not the case with my application. After the new year when I get time, Plans are to remove the A-Pillars and have them fiber glassed. Hopefully after that, I can get back to work on the doors for proper treatment. For now, I simply just don't have time to work on my Avalanche.
November 30, 20187 yr Author So now my son wants me to put everything aside and help him build a system for his 17 Chevy Cruze Hatch. I need a stiff drink.
November 30, 20187 yr Admin 8 hours ago, Randal Johnson said: So now my son wants me to put everything aside and help him build a system for his 17 Chevy Cruze Hatch. I need a stiff drink. I am here to help, unless you are pulling from personal stock.
November 30, 20187 yr Author 4 hours ago, Aaron Clinton said: I am here to help, unless you are pulling from personal stock. Thank you Sir. I will post up a couple of pics tonight of the Cruze. Start list will be a factory integration for pre amp output, 8” drivers in the doors (active 2way), and a single 12” driver in the hatch. Not sure or set on any particular Brands at this time. Just throwing ideas around. May get started on this shortly after the new year.
December 8, 20187 yr Author Finally, a little time for my Avalanche !!! I'd rather take an ass beating than to Fiber Glass ... LOL
