Posted May 4, 20205 yr Is this like a Bass eq or a gain knob? It has a clipping indicator which I've never seen on a Bass EQ knob. Oh and my install is nearly finished. I ran short on power wire (6" short uggh!) so I ordered some more. I would pick it up locally but it's hard to do with 'rona around
May 5, 20205 yr Admin It is a remote bass/gain knob with a clipping light for channels 3/4 when using it for sub duty.
May 5, 20205 yr Author I'm using it to bi-amp my tweeters (Ch 1/2) and mids (Ch 3/4) so I'm guessing it won't screw anything up if it's maxed out. Seems to work on boosting the lower midbass for the mids. Just making sure it won't screw with my EQ setting on the HU. Thanks!
May 12, 20205 yr Admin On 5/5/2020 at 6:30 PM, bigger_george said: I'm using it to bi-amp my tweeters (Ch 1/2) and mids (Ch 3/4) so I'm guessing it won't screw anything up if it's maxed out. Seems to work on boosting the lower midbass for the mids. Just making sure it won't screw with my EQ setting on the HU. Thanks! Nice, did you post install pictures?
