September 14, 20223 yr Author anyhow , i did the front section of my 2002 2dr blazer with 2 layers of 190 mil vibraflex , cooking it on with a map gas torch , yeah not much fun when it's already 90 degrees out !
September 18, 20222 yr Admin Yes, I have layered up a roof, it is worth it. If you want to double up, check for the least supported expanses of metal to double up on.
September 18, 20222 yr Author 7 hours ago, Aaron Clinton said: Yes, I have layered up a roof, it is worth it. If you want to double up, check for the least supported expanses of metal to double up on. i did just the front section there , the rest i went with 1/2'' mdf , kerfed it , then used a crap load of PL3x . but before i layed up the mdf , i filled the roof channels with strips of Vibraflex
September 19, 20222 yr I have a love hate relationship with installing sound dampening but it's so worth it at the end.
September 19, 20222 yr Author 16 hours ago, jcarter1885 said: I have a love hate relationship with installing sound dampening but it's so worth it at the end. so worth it when use a stiffening deadener to stop panel flex ! flapping panels suck
