  • Replies 69
  • Views 10k
  • Admin
Wow PE gives you terrible resolution on their plots. Sure is cheap enough to give it a shot. Personally I'd probably spend the extra $20 total and take it up a notch, but I have that tendency always. :Doh:
So you second the Dayton?
  • Admin
The I'd spend the $20 was my rec'd, but was trying to say it nicely. If you sell either used the better tweet will make up the cost difference in the end.
Ok, your approval on the choice means something. Also do you feel these tweets will get down low enough for the MLI's ?
  • Admin
Crap. You misread me since I typed incorrectly twice. I meant I'd spend an extra $20 on top of what those cost and move up to the Morels or Seas which both will go low enough for the Mli's.
Ok I am a doof. So since I am a little slow, which model Seas and Morels? I was looking at the MDT20's..
is that what dave has now? i can't remember
  • Admin
Actually I am not sure.
I think you should just toss a coin. They will all give you decent sound...
  • Admin
Humm, once its cleared by the boss maybe I can get this thing built!!
If the shop was kicking ass then I would expense it, but can't.
  • Admin
That will add to your crossover cost significantly. The TN28 is no gem either and you can really find a tweet that will blend nicely with the Mli so it is unecessary.
:thanx:
