Posted April 9, 200719 yr Bl 18, how much am I looking at for new Voice Coils in Dual 1ohm?And How hard are they to swap out. I want to be able to swap them for comps
April 9, 200719 yr Bl 18, how much am I looking at for new Voice Coils in Dual 1ohm?And How hard are they to swap out. I want to be able to swap them for compsChanging the impedance of the coils involves physically reconing the subs. So everytime you would want to change the coil config you would have to recond the sub. If I remember how the system works you can't just pick and swap to different coil configs unless you have the universal option... I could be wrong on that one though.
April 9, 200719 yr It's going to cost you 105 bucks to recone the sub every time you want to change the coil...
April 9, 200719 yr Author hmm plus the cost of the coils or is that included?..guess this isnt a good idea then...Maybe ill just throw more power to it, see how much I can abuse it before it blows, and then recone and change the VCs
April 9, 200719 yr hmm plus the cost of the coils or is that included?..guess this isnt a good idea then...Maybe ill just throw more power to it, see how much I can abuse it before it blows, and then recone and change the VCsThe VC is part of the recone, its a package deal.
April 9, 200719 yr Yup, the entire moving assembly would have to be replace (cone/surround, spiders, coil, tinsels) EVERY time. So, not an economical choice .nG
April 10, 200719 yr Author Its been a thought...Well actually One Fully Loaded BTL with alot more wattage...So i can stay in Street C
April 10, 200719 yr Hmmm... Street C (or A and B for that matter) normally do not get along with BTLs. They tend to have too much motor strength to peak hard enough in the lower power/ lower pressure Street systems. Super Street and Extreme are completely different applications though.Id figure that your BL should take high powe Street burps just fine, and probably peak a decent amount more than the BTL would. Remember that a burp is unitl the meter registers (3 or less seconds) and not 30 No high power sweeps, and let it cool in between runs. This will greatly help in keeping the coils together for many many happy burps.Thanks,Scott
