Posted May 4, 200719 yr hey allI was wondering in your installs with Fi subs1. What gauge speaker wire do you use for the subs ?2. What gauge power wire for the amps powering the subs...??3. how many watts going to you subs (per sub)I am in the process of finalizing my system and was going to do a look over all my wires....thank you all i appreciate itCliff
May 4, 200719 yr 8 guage for sub1/0 for ampnot sure how many watts, but if my electrical was up to par it would be over 2000 i think.
May 4, 200719 yr Author tpjrso the coils you use 8 guage then from sub to amp 4 guage ?how many watts per sub you got?
May 4, 200719 yr 8 AWG to sub0 AWG from bat/ground to d block then 4 AWG from d block to amp~1400 rms to BL 12 @ 14.4v
May 4, 200719 yr tpjrso the coils you use 8 guage then from sub to amp 4 guage ?how many watts per sub you got?to be honest with you not alot, im running 4 ssd's per soundstream 6500d but that only puts out maybe 3k on 12volts, the amp accepts upto 4 guage speaker wire so i figured what the hell go for it
May 4, 200719 yr I used 8 guage to each coil since that's what the terminals will accept (and my amps)2x 1/02 memphis 4ks on 2 btls- who knows after voltage drop.
May 4, 200719 yr 1. I currently use 12gauge.2. I use 0gauge. If I ever go with more or bigger amps a second run will be put in.3. I have roughly 900 watts going to each Q 12.
May 4, 200719 yr this in an istall im about to do for a friend.2 runs of 1/0 power and ground (4 total)3 batts12 guage wire to the subs1000 watts per sub on 4 15" SSD's
May 4, 200719 yr 1. 10 gauge for the subs2. 0 gauge for the amp power3. 4000wrms to each sub (total of 2 subs)
May 5, 200719 yr power.....0speaker... 10 i think, dont rememberwatts...... little more than 1000 watts rms12" Fi Q
May 5, 200719 yr Author Wow i honestly didn't know most of the users here use 8 gauge for the subsKeep'm coming....I had 10 gauge on mine 1K to each suball 0 gauge on amps...gonna get me some 8 gauge for my Q's when i order them
May 6, 200719 yr 8 to subs 4/0 from front to back 1/0 across 10 batts and a 12 f stinger capand 4 to ampabout 2500 to 1 15btl will double when i get the other 15 indid my first bass race with the sub cant wait to get my coil inso ill have both 15 in veryvery happy with my sub Edited May 6, 200719 yr by teamriles
March 25, 201115 yr then why not10 gauge to subs 1/0 to amps 2 18's gen 2 btls on 2 aq 3500D.1 strapped
March 25, 201115 yr 8 gauge to sub (raptor wiring) and then 0 gauge ground and for amplifier, and all 0 gauge under the hood! 2000-3000 rms to 1 18" BTL N2 @ 14.4 volts tested!
March 25, 201115 yr Lol at everyone commenting at old thread.. but since it's up again, I use 12awg for speaker to amp, 4awg power/ground, 1200w to 1 Fi ssd Is there a difference in power wire & speaker wire?.. or are they interchangeable.. ( do i need more than 12awg for my sub to amp?..)
March 25, 201115 yr Lol at everyone commenting at old thread.. but since it's up again, I use 12awg for speaker to amp, 4awg power/ground, 1200w to 1 Fi ssd Is there a difference in power wire & speaker wire?.. or are they interchangeable.. ( do i need more than 12awg for my sub to amp?..)Nope. 12 is more than fine
March 29, 201115 yr 8 gauge to subs 4 runs 1/0 gauge to batts and amps 2 18" btls on 2 US AMP md3d 2000rms ea
